Sponsored by:
Sponsored by:
How much weight should I put in the trunk?
Old 01-09-2009, 07:35 AM
Tim From Cleveland
Tim From Cleveland's Avatar
Default How much weight should I put in the trunk?
The roads are starting to get bad and I wanted to pick up some sand bags to throw in the trunk. How much weight is a good amount to pick up?
Tim From Cleveland is offline
Old 01-09-2009, 07:42 AM
Nuke
Nuke's Avatar
Whatever the typical dead body weight is...
Anything less than 100 #'s is probably useless. It's been a long time since I've had to do that (have owned 4x4's for 20 years now plus moved a bit more south recently!) but I'd say at least 150.
If you MUST drive your Stang in snow, then hopefully you've replaced the stock garbage rubber with something more suitable for your weather.
Nuke is offline
Old 01-09-2009, 07:44 AM
limitedex
limitedex's Avatar
Everybody's gonna say different, but I think that would work without overdoing it. Anything will help. Just try different weights and see what works for you. I'm in Erie and I put four or five 70# bags in my truck to keep weight back there.
limitedex is offline
Old 01-09-2009, 08:08 AM
ptaylor_9849
ptaylor_9849's Avatar
Not that you want to spend extra money but I know how you can get thru the harshest winters with absolutely NO EXTRA WEIGHT. Put on some Michelin X-Ice 2's. My winter car (below) is a GT with a 93 tune and 4:10's and my car goes thru snow and ice like a 4X4. The secret is the softness of the tire. Moreover, because they're so soft they are the absolute quietest tires I have ever driven on and I've owned 50 cars! I speak from experience as we've already had over 2 feet of snow in the last month. Like all Michelin's they are pricey but worth every penny.
ptaylor_9849 is offline
Old 01-09-2009, 08:59 AM
iROK24/7
iROK24/7's Avatar
+1 on the Michelin X-ICE they're GREAT! I put 'em on my car & the difference is NITE & DAY! Now SUVs pull over and let me pass!
iROK24/7 is offline
Old 01-09-2009, 09:02 AM
UltraKla$$ic
UltraKla$$ic's Avatar
I've got a mother-in-law you can put back there. Be forwarned, your gas mileage WILL increase.
UltraKla$$ic is offline
Old 01-09-2009, 09:25 AM
drfister
drfister's Avatar
I'd put at LEAST 2 bags. It adds some weight yet retains some trunk space. Add more if needed. +2 for X-ice tires. Have em on all 4 corners and this puppy holds her own in the snow with the best of them.
drfister is offline
Old 01-09-2009, 09:32 AM
Tim From Cleveland
How much do these Michelin X-ICE tires cost? Who is a good dealer to get them from?
Old 01-09-2009, 09:44 AM
AshGT
AshGT's Avatar
I have about 120 pounds of sand bags over the rear wheels (one on each side) with bridgestone blizzaks on my '08 GT and for the most part it's done pretty well this season, and we've been covered with snow and ice pretty much all winter. The blizzaks were around a grand for set of 4 though.
AshGT is offline
Old 01-09-2009, 09:48 AM
UltraKla$$ic
Cheaper to move South.
Quick Reply: How much weight should I put in the trunk?
