Sponsored by:
Sponsored by:
Gt 500 spoiler: The Spoiler Store
Old 03-19-2009, 10:58 PM
  #41
TheLowsters
TheLowsters's Avatar
Is it possible to order GT500 spoiler painted from the dealership?
TheLowsters is offline
Old 03-20-2009, 12:22 AM
  #42
antonio1988
antonio1988's Avatar
probably but don't bother, you'll spend twice as much there as you will on eBay and you have lots of people here including myself that will vouch for the Spoiler Store on eBay.
antonio1988 is offline
Old 02-01-2010, 10:45 AM
  #43
SnakeHandler
SnakeHandler's Avatar
Does the GT500 spoiler from The Spoiler Store use both sets of mounting bolts on both sides like the oem GT500? Many aftermarket spoiler vendors sell a spoiler that only uses one bolt per side.
Thanks for the help!!
SnakeHandler is offline
Old 02-01-2010, 11:57 AM
  #44
Misbehavin
Misbehavin's Avatar
You can use one bolt per side, with the 3M tape and be fine. There are provisions on the spoiler allowing you to use more fasteners. However, to use those would require drilling the decklid.
I opted not to drill, and I'm now approaching the 1 year mark and it's doing just fine. I'm also very picky about the fit and finish of a part.
Misbehavin is offline
Old 02-01-2010, 01:17 PM
  #45
SnakeHandler
Thanks for the reply Misbehavin! So what you are saying is that the spoiler from The Spoiler Store does not come with two bolts per side, just one.
Old 02-01-2010, 01:32 PM
  #46
Cal26Stang
Cal26Stang's Avatar
Is the spoiler plastic?
Cal26Stang is offline
Old 02-01-2010, 02:15 PM
  #47
Misbehavin
Misbehavin's Avatar
No, it comes with two per side, but you only have to use one. Bear in mind that these "bolts" are really studs, and you only thread in what you need. The other spots are optional, and most people choose not to install them. Just for clarification, the two optional holes with this spoiler are out towards the sides of the trunk lid, not directly forward of the factory holes. I wish I had a picture of mine handy, but I don't.
The unused factory holes should be sealed with some silicone sealant to avoid any water finding it's way into the trunk.
Old 02-01-2010, 02:58 PM
  #48
DRock
DRock's Avatar
I will vouch for them i love mine.
DRock is offline
Old 02-01-2010, 03:26 PM
  #49
LegendLives
LegendLives's Avatar
I will chime in also. I got mine from the spoiler store and paint match was spot on but the finish left something to be desired. The good thing though was it has plenty of clear coat so you can wet sand w/ 2000 grit and rub it out w/ a 3M polishing material. Yes I'm a little ****, I mean particular. lol As far as the second set of holes I would not drill them, I did and wished I didn't. I didn't hurt anything , but with the set of holes that do line up and the amount of 3M tape that sucker isn't going to go anywhere.
LegendLives is offline
Old 02-01-2010, 04:46 PM
  #50
07gtdude
07gtdude's Avatar
got mine from them installed this weekend. fit and finish is great and it looks much better than the regular gt spoiler.
07gtdude is offline
Quick Reply: Gt 500 spoiler: The Spoiler Store
