Sponsored by:
Sponsored by:
a few racing questions
Old 04-13-2009, 01:39 PM
cobrakiller347
cobrakiller347's Avatar
Default a few racing questions
hey i live in michigan and on the 25th they are having the high school nationals and my old teacher said he could get me in the races anyway i need my car to run at least 13.99 to be in bracket 1. so my questions are i have a 5 speed 09 gt bone stock im a good driver wat are my chances of getting 13.99 or faster? also wat can i do cheap to make sure i hit at least 13.99 or faster?? i already plan on removing the passenger seat and spare tire...
cobrakiller347 is offline
Old 04-13-2009, 01:54 PM
kpaulhus
kpaulhus's Avatar
rear seat, spare tire, passenger seat. As far as a cheap mod to get a little kick, I dont know of any quick power gains for the track. Maybe make sure your tire psi is lowered a little bit and give it a few runs. My best run in my stock 07 was a 14.3, but I was on 20's.
kpaulhus is offline
Old 04-13-2009, 01:59 PM
cobrakiller347
im gonna run up there on wednesday and see if i can tag a 13 with everything intact in my car. i just found out they have a test and tune that day
Old 04-13-2009, 02:11 PM
kpaulhus
kpaulhus's Avatar
sweet. My test n tune is Thursday in Bradenton.
kpaulhus is offline
Old 04-13-2009, 03:44 PM
Apoptosis
poptart tits
Apoptosis's Avatar
+1 with kpaul, take out the spare tire(40ish lbs removed,) deflate your rear tires by a few psi and inflate them back up when you are done.
Taking out the seats pretty excessive, for starters the 09's come with an intake I think(they have +15 HP from the factory) soo.
If you really are a good driver, which no high schoolers are. You shouldn't have any problems running into 13's. Stock I ran 13.67 and that was when I was in high school. :P
Practice your launches in a parking lot beforehand. I found that on the stock pirellis that launching over 2,000 RPM's causes you to spin like a mother. And don't smoke your tires before every launch either, a small spin before the first launch is all you need.
Apoptosis is offline
Old 04-13-2009, 06:40 PM
kpaulhus
kpaulhus's Avatar
it all depends on the track condiditons also. I was able to launch around 3700 rpms because the track was soooo sticky.
kpaulhus is offline
Old 04-13-2009, 09:20 PM
chub46
chub46's Avatar
For a cheap mod get a set of Mickey Thompson et street tires and you will be in the 13's.
chub46 is offline
Old 04-13-2009, 10:40 PM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Last I checked with a good driver the car can do 13.4-13.7 in the quarter mile totally stock....I just saw a time slip for a guy that did 13.0 in the quarter mile totally stock
mygt500 is offline
Old 04-14-2009, 01:04 AM
SikO7GT
SikO7GT's Avatar
+ 1 to above!!
Make sure you have no more than about 1/4 tank of gas for less weight!! Practice launching it and feather the clutch so you dont spin!!
Go on a diet yourself if you can!! Kidding (eat a burger)
You could always add a drop in K&N filter which would give you like 5 quick horses max!! (50 buck mod)
SikO7GT is offline
Old 04-14-2009, 08:39 AM
VistaStangGT
VistaStangGT's Avatar
I was running 13.9 on 19" tires and rims. Get some ET Street Radials, heat them up really wll and you'll be doing at least 13.7.
VistaStangGT is offline
Quick Reply: a few racing questions
