Charge motion delete plates
If you dont want to spend the money for plates just have your tune adjusted to have the plates always open. Granted you will still have a small restriction from the plates being in there. Just another option.
Isn't that in fact the whole point of these plates; to get rid of the restriction when they are full open?
When the plates are full open, while in theory it's a restriction, it's so small you won't notice it unless you're running a lot of boost or something.
The HP difference between full open and deletes is about as small as the difference between the stock TB and an aftermarket TB (assuming N/A here)...if that. Just not enough to get excited over. If the delete plates were A LOT cheaper then it wouldn't be so bad.
I think the bigger difference comes during the times when the plates are not full open.
+1^ With the plates wide open, the drag from those plates is very minimal. Especially in a N/A setup. I dont believe you can adjust them yourself with the tuner, I just went by Brenspeed and had them drive my car for a bit. Then went back to the shop and they tweaked a few things in my tune. WOW what a difference I felt just from having the plates put to all open.
another thing against the use of plate deletes on an N/A car, you WILL lose Tq on the low end with the butterflies removed (deletes installed). Ask doug or brent (bamachips/brenspeed respectively). Deletes are best for boosted cars or those that have cams where the loss in low end TQ is well made up for by the power adder.
I just did mine. It is a simple install and cleaned the fuel injectors and the whole area while I was there. 150 is not much, there is slight gain on hp and the sound on my borlas got deeper. I also noticed some very nice roling on the sound when I let the throttle go. I have brenspeed tunes and I bought the delete from them so they tunned the cmdp's for free. God bless them... I am planning to do cams and LT as well and the deletes are a good complement to them
