Why can't you lift by differential?
#22
On another car of mine the rear axle is slightly bent so that both rear wheels are cambered slightly (about -0.5° each). True, that's not the way a jacked-by-the-pumpkin axle would bend, but it does suggest that axles can in fact bend. Unfortunately, it's a replacement axle, so I do not know its entire history and it never occurred to me to measure it up right after it had been installed or to have measured the original axle to see if a slight negative camber back there was an OE within-tolerance item.
Norm
Norm
#23
jack
Well, If you think about the auto industry has been trying for years to keep people from working on there on cars. How many people have a lift at home to use on there car?
Also I'm sure the liabilty has something to do with it. McDonalds hot coffee spilled in the lap brings millions car falls of jack brings??????????????
Steve
Steve
#24
Trust me, I'm getting to the point where I really would appreciate having a lift. Bench-pressing trannies in and out and welding up exhaust systems and what-not while laying out of position on my back has gotten old. I've got to get down on my back this week to replace an alternator on my autocross weapon/winter beater this week and I'm not particularly looking forward to having to do so.
There are a few problems with having a lift. Most lifts are $2000 and up (see the latest Hot Rod Magazine advertising section), not all are rated for use as repair lifts, and the neighbors (and ultimately the local zoning board) might not appreciate most of what's available. The lift may not be rated for wind loading, and most home garages don't have the required interior height or may have a sloping floor for drainage. I might be able to engineer my own lift, but after being around commercial lifts I'm not fully convinced that I possess the requisite fabrication skills or that my welding equipment is sufficiently heavy duty to do a proper job.
You're probably right about the liability issue being part of it.
Norm
Norm
#28
Okay, I guess I don't get it. I haven't been a part of this forum for long, so I haven't been a participant in past threads on the subject, but it sounds like this debate has been going on a while now.
I just don't understand - The Ford engineers who designed the car tell us not to do something. Just by looking at it objectively, I can see why.
But then everyone wants to jump in and explain why you should do it anyway, even though it takes a minimum of effort and time more to do it the way the designers recommend.
What's Ford's stake in telling us not to do this? Do they have tiny little surveillance cameras hidden in our cars so they can watch every time we jack our cars up by anything other than the diff? They sit back and laugh, and call us names such as "sucker" or maybe "gulla-Bull", patting each other on the backs? They record the footage and play it back for all their friends, shouting things like "Ha! they could have been jacking their cars up by the diff this whole time! Instead they took the extra five minutes to jack it up at the pinch welds!"
I'm done with this thread. You guys have a good time.
I lift the front under the engine cross member, but I'm sure Ford doesn't consider that a jack point either.
#29
For the short duration of getting the corner up onto a jackstand this should not be particularly worse than jacking up one corner to remove a flat and replace it with the spare. IOW, this is not an issue at all for any car that's in sound structural shape.
I would not make a practice of leaving only one corner of the car raised up on either a jack or a jackstand for an indefinite length of time though.
Norm
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
KingRando
10-02-2015 08:06 AM
