Front popping
I just wanted to post that it turned out it wasn't the coil insulator. Today, I was determined to find the popping sound that continued to come from my front end. It almost felt like the tire was actually shifting some. So, I figured there had to be a loose bolt somewhere on the LCA. Sure enough, the front bolt, the one that has the nut mounted permanently to the car was pretty loose. I tighten the heck out of it and check everything else as well.
Did a test drive and not one sound........so far. FINALLY!!!!!!
