Sponsored by:
Sponsored by:
A little help
Old 06-12-2009, 11:18 AM
ABQstang89
ABQstang89's Avatar
Default A little help
So just the other day I noticed that my power locks were not working on the driver side. The lights on it wont even work. Does anyone know how what I need to do to fix this? I also just got the check engine light. Can I use my tuner to find out why its turning the check engine light on? If I can how do I do it cause I've never done it before. I have an xcal 2 but I've never used it.
ABQstang89 is offline
Old 06-14-2009, 08:36 AM
ABQstang89
ABQstang89's Avatar
bump....
Old 06-14-2009, 10:16 AM
avengence
avengence's Avatar
Yep you can read and clear the DTC's (error codes) with your tuner. Just plug it in and go to the DTC/Data menu and click read DTCs. After that it will give you a set of numbers and letters. Then you look on http://www.obd-codes.com/ and check what it says about your code.
A lock problem wont throw an engine error code, it just could be happening at the same time. Anyway, read the code and tell us what it is then we will go from there with the door locks.
avengence is offline
