2010 Shelby Wheels
Wheels offset is measured from the center line of the wheel either positive or negative where the hub of the wheel meets the axle mounting surface. Our wheels have positive offset. Basically if the overall width is 9" for instance, zero offset is dead center (4.5"). Our wheels stock offset are 50mm I believe. Offset is very important for both clearance and overall looks. Hope this helps you out. See attached "stick" demonstration
Are you talking about these?
http://images.google.com/images?hl=e...-8&sa=N&tab=wi
If so, I would be surprised if you could buy them new... even the Bullitt wheels require that you have a car with the Bullitt VIN.
Galactic
04-29-2019 02:56 PM
Other Professional Racing
09-10-2015 11:41 AM
