Sponsored by:
Sponsored by:
Possessed SmartJunctionBox
Old 09-09-2009, 03:12 PM
157dB
Cut & Paste Expert
157dB's Avatar
Default Possessed SmartJunctionBox
The other day I was looking at the new Camaros and lil miss stang
didnt quite like it. When I went to lock her up with the remote that
evening, it would not work. Nothing worked via the remote. No trunk,
no nothing. Then when I went to open her up to see what the deal
was, the interior lights didnt come on for about 5 seconds then started
flashing. The door lock switches on the doors didnt work and the Accessory
Delay feature was hit and miss. When the headlights were turned on, there
was another 5 second delay before they actually illuminated. When turned off,
they continued to illuminate for about 5 seconds more. Every electrical item
that runs thru the Smart Junction Box had about a 5 second delay. The turn
signals were non-functional and the brake lights also had the 5 second
turn on/turn off delay. I gave it up as it was late and chalked it up to the
leak problem and a corroded SJB. I eventually got around to working on
her the next day and the first order of busisness was a power down/power
up cycle to 'reboot' the SJB logic. This seemed to straighten out the problems
all in one mighty swoop of pulling SJB fuses from the BussedElectricalCenter
under the hood. This is the first time I have ever heard of this sort of problem
with a simple power down/power up procedure fixed it. I did pull my SJB and
inspected it for any signs of corrosion and none were present.
I guess I lucked out. The warranty expires in 3 months....
157dB is offline
Old 09-09-2009, 03:23 PM
Nuke
Nuke's Avatar
Well, YOU'RE the expert in these matters! Low voltage from a weak battery?
Nuke is offline
Old 09-09-2009, 04:21 PM
157dB
Cut & Paste Expert
157dB's Avatar
Nope, I have a custom trickel charger.
Its got me baffled.
The flashing dome light is a new one round here....
157dB is offline
Old 09-09-2009, 04:29 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Your car has been possesed....nothing you can do about it now. Shouldn't have checked out the Camaro in plain sight of your car
Derf00 is offline
Old 09-09-2009, 06:18 PM
whyask
whyask's Avatar
what about a bad alternator.....also. i know you have a trickle charger but is it the stock battery ..??
whyask is offline
Old 09-09-2009, 06:37 PM
Nuke
Nuke's Avatar
Let us know if it begins spitting green liquid (other than antifreeze) and if the front wheels begin to turn 360 degrees left or right...
Nuke is offline
Old 09-10-2009, 08:58 AM
157dB
Cut & Paste Expert
157dB's Avatar
Alternator is fine.
MSD DashHawk keeps tabs on module voltage.
I have a new 09 motorcraft battery.
Battery connections are top notch.
Battery gets a 15V 'cell equalization' charge
every so often because of its partially dormant state.
Its not the basics here, folks.
But I will entertain all forms of ideas....
157dB is offline
Old 09-10-2009, 09:34 AM
NaplesFL11GT
NaplesFL11GT's Avatar
Ahh yes the dreaded SJB. I wish I could figure out on how to turn off my DRL's through my SJB.
NaplesFL11GT is offline
Old 09-10-2009, 11:27 AM
Nuke
Nuke's Avatar
Well, 157db. This sounds like one where the expert needs to call his mentors.
Nuke is offline
Old 09-10-2009, 11:33 AM
Art161
Art161's Avatar
Or an exorcist.
Art161 is offline
Quick Reply: Possessed SmartJunctionBox
