Questions on painting stock rims
Kinda considering painting mine since i cant afford the ones i want for a while...
What would be the best paint to do this properly.
I hopefully can find the time to do this properly but want to make sure it turns out good.
I have a paint sprayer although its not a great one.
Should i bother with a good type of paint or just get some spray paint and wet sand a while?
Ill probably wait till i find a used stock bullitt rim on CL and test it out first since i see a few damaged ones get split up and sold every now and then.
Don't even waste your time painting them! Powdercoat them. You can get them done for about $35-$40 per wheel in any colors you want. I just had the wheels on my wifes car powdercoated 60% gloss black(from factory silver) because nobody makes a stock sized aftermarket wheel for it. Powdercoating is what's done with all factory coated wheels. Paint will come off fairly quickly.
if you prep the rim with sandpaper and use a ton of light thin coats with the spraypaint...and then follow it up with clearcoat
I've seen that setup come out looking really nice, and they last. especially if you use a self-etching paint as a primer first. between that & the sandpaper, you get a great adhesion surface.
powdercoating is an option, but once it chips, you are screwed. and the majority of powdercoating jobs lack any luster or shine. the ones I've seen in person are all dull and flat looking.
powder coating isn't worth the money, plain and simple - my friend paid quite a bit to have the fake beadlock-look trim rings on his MT wheels done and they have several chips and nicks in them - look at the frame of a harley that's actually ridden ...you'll find several chips, scratches, etc.
i painted the inserts on my wheels a couple years ago and they don't look too bad, a few chips here and there, but i also have to drive down a 1/2 mile of dirt/rock road to work everyday too.
sand paper to scuff the surface, prime, paint and clear - you can do it yourself for not much money at all, only time
http://www.harley-davidson.com/wcm/C...p?locale=en_US
dude, we get it. Powdercoating gives you a raging hard-on.
We all have our opinion, but it'd be nice if you left the rudeness at the door. Sorry we can't all circle jerk together. it just ain't meant to be.
