Hurst Questions Search Didn't Answer ;)
OK...I'm burnt out reading all of the post on Hurst installs and the "issues" with rattles.
BTW, thanks to everyone for the great tips.
My questions:
1) There is a rubber plug in the end of the stalk going to the front of the tranny but nothing inside. Has anyone filled this with lead shot or something to reduce vibration? Similar to the stock panhard bar.
2) I found one post with a comment about a shorter FRPP stick to bring it back to stock height. Has anyone used it and did it make the shifter throw extremely short?
Sorry for yet another Hurst question and thanks for any help.
Mark
My questions:
Mark
1) no but that might help
2) I haven't used that so I wouldn't know for sure but I would think that you would have problems doing that since it would take away a lot of your leverage and it's a little notchy to begin with.
I love my Hurst shifter, it did rattle a little at first but then stopped on it's own after some time. some people added gun oil to the bearing and that stopped it from rattling.
the k-member brace with the torque limiters made shifting in this car perfect, stopped the engine from flopping around and messing with shifts.
I'm using the shorter black stick with the stock ****. Shifts are a bit shorter but not too bad. Shifting is not harder than with the chrome stick and ball.
I just did the gun lube in the bearing and locktite on the handle bolts and mine has been perfect. Just get those handle bolts on REAL tight. Had mine installed by a Ford tech who was very experienced/knowledgable with the Hurst shifter and he did an awesome job. No issues with rattle for me.
If you put a rubber gasket between the shift arm and the shifter, most of your noise will cease. You can make your own or buy one from this guy:
http://stangshiftergaskets.com/
Thanks for the help guys.
If I can find the short FRPP arm, I'll pick one up and try both set-ups out.
tr6nut
I ordered the gasket. For that price it saves me from looking around for a suitable material. Thanks for the link!
tr6nut
iROK
I think I understand what you are doing with the "silencer", but I can't picture how you are doing it with a 1" pool hose.
Am I correct that you are holding slight tension on the spherical bearing with the hose to keep it from rattling?
Can you elaborate? This is a new one and I'm open to any suggestions.
