Please help car wont idle right
I have installed a stage 2 procharger with an upgraded head unit and a 800 hp innercooler along with 60lb injectors, ht0 spark plugs and -Fore Precision Works S197 Billet Fuel Hat
-Lethal Performance Dual FPDM Kit
-Hat to Stock Fuel Line Adapter
-Ford GT Supercar Fuel Pumps (2)
-Fuel Level Sending Unit
I installed it in and the car will start up and idle for 5 seconds and then turn right off. the fuel pressure is going from 25lbs to about55lb or so then turing off, i had a shop take a look at it and they can not figure it out. please does anyone have an idea what is wron with it i need my car back. Or any one with the fuel system that i have, did you have the same problem?
When you put the key to the 'On' position before you crank it, do you hear the fuel pump kick on?
While it does idle, is it smooth or rough?
After it shuts down can you go right back and start it up again or does it need to sit for a few minutes?
Uhhhh, yeah, same question. You can't simply swap to 60lb injectors with being tuned for them.
You have changed so much, that I wouldn't even know where to begin. Clearly one or all of your mods are the problem.
Try disconnecting the battery for 15 minutes if you haven't all ready. That way the long term fuel trims will reset.
That kinda happened to me when i was changing between tunes and the tune half installed and did that same thing so i put the key in the ignition and turned it to run(all the way without starting) and back to where i can take it out. I did that about 10 times really quick until you can hear the door lock and unlock by its self. That resets the computer. Good luck
NJMustangGt, is the shop you took it to creating a custom dyno tune for you?
if so the base file that they start with should at least get the car to idle, unless of course there is a physical problem with the fuel system, sensor, etc.
