Sponsored by:
Sponsored by:
Front tires or rear tires wear faster?
Old 08-12-2010, 08:46 PM
mav2k
mav2k's Avatar
Default Front tires or rear tires wear faster?
In a RWD Car Front tires or rear tires wear faster?
Thanks in advance.
mav2k is offline
Old 08-12-2010, 09:04 PM
Cal26Stang
Cal26Stang's Avatar
rear tires generally wear faster...especially with a mustang...the driver
Cal26Stang is offline
Old 08-12-2010, 09:05 PM
Nuke
Nuke's Avatar
Rear if you're spinning them, front if you're pushing thru the twisties and cornering very hard.
Nuke is offline
Old 08-12-2010, 10:01 PM
imfamousjim
imfamousjim's Avatar
yup, depends how you drive it. I kill my fronts by running lots of negative camber and turning/braking hard, but the rears seem to last quite a while
imfamousjim is offline
Old 08-12-2010, 10:16 PM
Vader GT
Vader GT's Avatar
Same for me!!!
Vader GT is offline
Old 08-12-2010, 10:29 PM
Mustangmaster
Mustangmaster's Avatar
If you don't rotate very frequently, you'll find out. Yes, my experience has been the back tires wear our faster.
Mustangmaster is offline
Old 08-12-2010, 10:32 PM
Diabolical!
Diabolical!'s Avatar
Weird, I've always found my front tires wear faster, regardless of whether I'm driving FWD or RWD. Then again, I take it pretty easy on the street and run slicks on the rear of the stang at the track. If you're running equal sized non-directional tires on all four corners, then they should wear evenly (cough* rotate hint* hint*).
Diabolical! is offline
Old 08-12-2010, 10:38 PM
kenthicken
kenthicken's Avatar
I wiped out my fronts pretty quickly with my negative camber.
kenthicken is offline
Old 08-13-2010, 01:02 AM
Alec
Alec's Avatar
Definitely rears for me. Gotta keep them rotated and balanced
Alec is offline
Old 08-13-2010, 02:06 AM
Cal26Stang
Cal26Stang's Avatar
thats the only sucky thing about having a badass staggered setup with directional tires...no rotation
Quick Reply: Front tires or rear tires wear faster?
