Sponsored by:
Sponsored by:
Old 11-04-2015, 11:38 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brake Guides
Print Wikipost
e-brake cable snapped, need advice
Old 08-23-2010, 08:11 PM
steve r
steve r's Avatar
Default e-brake cable snapped, need advice
Hi, so my 2005 mustang gt e-brake cable is snapped. I know there is a TSB on it and I tried searching but I cant find exactly what needs to be replaced. This happened last winter by the way, everything froze. Mine snapped on the front cable where the ball thing is where it meets the two rear cables. What do I need to replace besides the front cable? Someone told me that I might have to change the rear calipers too and also the rear cables, but I am unsure and im wondering if anyone has any advice! thanks in advance
steve r is offline
Old 08-23-2010, 08:56 PM
ShaneM
ShaneM's Avatar
i had that happen last winter when i still had my 05. they told me at the shop some crap about the calipers being locked up and needing to replace them too. i refused to do it and insisted they only replace the cable and it was fine. All you need is the cable, I had to order from ford and it seems it was about $100 installed and all. Assuming you didn't drive it with the rear brakes locked and damage something you should only need the cable.
ShaneM is offline
Old 08-23-2010, 08:57 PM
Nuke
Nuke's Avatar
https://mustangforums.com/mustang-ts...-DRAGGING.html
Nuke is offline
Old 08-23-2010, 09:13 PM
steve r
steve r's Avatar
thanks for the info.. Also, my front cable snapped, how come i cant find one online? even on fordparts.com I cant seem to find it
steve r is offline
Old 08-23-2010, 10:14 PM
steve r
steve r's Avatar
this is where it snapped, and I cant seem to find one arghhhhhhhh
steve r is offline
Old 08-23-2010, 10:55 PM
2005Redfire6
2005Redfire6's Avatar
Thats kinda scary being I have an 05 and it gets cold here in the winter...
2005Redfire6 is offline
Old 08-24-2010, 12:38 AM
up_yours_7
up_yours_7's Avatar
Mine broke in the same spot I haven't found anything yet to fix it
up_yours_7 is offline
Old 08-24-2010, 07:48 AM
steve r
steve r's Avatar
did you go to ford?
steve r is offline
Old 08-24-2010, 10:28 AM
kevinmalec
kevinmalec's Avatar
My e-brake froze during an ice storm one year. I tried moving forward and backwards and wasn't able to move. Fortunately, the cable did not snap or break. I searched the Mustang forum and learned about the TSB on the e-brake. I let it set in the parking lot until it thawed the next day. I avoid using my e-brake during the winter time, which is short here in GA. =-)
kevinmalec is offline
Old 08-24-2010, 10:56 AM
steve r
steve r's Avatar
well I went to ford and they said the front cable is attached to the parking brake lever so I need a whole new assembly. the part is 120 which is fine, but 3 hours installation!! 472 dollars for it installed. I think im just going to order a new one, found this one, http://www.nthcoast.com/store/produc...roducts_id=382 and install my myself
steve r is offline
Quick Reply: e-brake cable snapped, need advice
