Sponsored by:
Sponsored by:
Car won't start....is this a jump situation?
Old 11-02-2010, 02:19 PM
Nuke
Nuke's Avatar
Is it the OE battery? You know the issues...
Regardless, a battery can catastrophically fail at anytime, most often while driving but you'll never know it until you shutdown and go to restart. A jump should get you started but if the battery is kaput you won't be able to restart it. Hopefully your battery is just discharged for whatever reason but suspect the worst and plan on a replacement.
Nuke is offline
Old 11-02-2010, 02:40 PM
Cal26Stang
Cal26Stang's Avatar
It makes a weird noise when I put my foot on the gas...sounds like a scanner or something
Cal26Stang is offline
Old 11-03-2010, 08:11 AM
Nikodemos
Nikodemos's Avatar
Make sure the battery's water is full before buying a new one...
Nikodemos is offline
Old 11-03-2010, 11:43 AM
157dB
Cut & Paste Expert
157dB's Avatar
What you need to do is drain that oil thats contamminated
with SeaFoam before your bearings start to wear abnormally...
157dB is offline
Old 11-03-2010, 03:23 PM
kevinmalec
kevinmalec's Avatar
My car is also a daily driver and the battery died about 3 weeks ago. I had the battery a little over 2 years. When I attempted to start the car, it made clicky sounds. I took it out and went to Autozone to get it tested and it was completely DEAD. I replaced with a new battery and the car ran great!! It was like installing a new tune all over again!! =-)
kevinmalec is offline
Old 11-03-2010, 03:32 PM
Nuke
Nuke's Avatar
Yep, there's a world of difference between "clicky" and "vroom". Not to mention that you also cleared the Adaptive Learning...
Nuke is offline
Old 11-06-2010, 08:58 AM
157dB
Cut & Paste Expert
157dB's Avatar
BATTERY REPLACEMENT PROCEDURES
FAIL
157dB is offline
Old 11-06-2010, 12:51 PM
RichieCal
RichieCal's Avatar
My battery died a few months back..I used the search function as 157 db is always preaching and found that the factory battery doesn't last more than 3-4 years, so doesn't suprise me yours went..I also remember reading about the shaker 500 draining the battery if you don't shut the radio when u shut the car off..I turn it off now everytime to be safe
RichieCal is offline
MXBT187
08-20-2015 02:36 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
ccwebb
08-11-2015 06:47 PM
Darrens07GT
08-10-2015 03:59 PM
Quick Reply: Car won't start....is this a jump situation?
