Friction Modifer?
Friction Modifer?
Do you need to add it in a V6 when changing the differential fluid? Im planning on going with PR or M1 Syn fluid. I think I read somewhere the V6's do not have a lsd therefore does not need the modifer, is that right or wrong?
Thanks,
Thanks,
I suspect you're correct (that not having LSD means you don't need the modifier) but I'd wait until you hear from a V6 owner that has replaced their diff fluid... successfully.
I'm swapping the 7.5 for the 8.8 this weekend and need some friction modifier along with the diff fluid. Any suggestions?
Probably gonna go with 2 bottles of this:
http://www.americanmuscle.com/royalp...0-gearoil.html
Edit: wrong link
Edit: wrong link
Edit: wrong link
Edit: wrong link
And although RP says you don't need the FM,
I bought the little bottle of FM from Ford and put it in.
How do you like the 8.8 & 3.73s vs. stock?
MPG is better in town. Worse on the highway. But not by much.
I just ordered the 4" Shaftmasters aluminum DS.
Should deliver next Monday.
