Which alternator to buy
Hello,
So Im getting the Check Charging System message, I already took the car for tests and they say is the alternator and maybe they can fix it.... They will need to check the alternator to be 100% sure.
Im thinking on buy a new alternator but after reading so many threads motorcraft is my last choice, which ones do you recommend ?
If i cant get them in Mexico i will be ending buying motorcrap....
Thanks
Mustang 2007 GT V8 Manual
Thanks
Why can't you order online from PA Performance? I'd get the 130 amp unless you have some heavy duty aftermarket power hungry electronics. If so, then the 200 amp should do the trick.
Im still trying to get it here in Mexico if not then i will see if I order it online, I dont know the fee for that here too...
Do i need this upgrade "** We require that you upgrade the main power wire due to higher output than stock on vehicles where this is an upgrade**"
That means i will needto orderthe power wire too ?
Thanks!
If i get the PA Performance Alternator the total cost would be 450dlls plus the fees i will need to pay here. I think i should get one from Mexico.
Does anyone recommends the duralast gold or any other brand ?
Thanks
