Sponsored by:
Sponsored by:
Boss 302 Laguna Seca Underneath
Old 04-17-2011, 08:08 AM
wcgman
wcgman's Avatar
Hmmm....It really dont bother me none. But it aint off the hook either for me on the appearance side...
wcgman is offline
Old 04-17-2011, 12:44 PM
JIM5.0
JIM5.0's Avatar
Originally Posted by 92hatchLX
I personally would really like to see just side pipes (no rear exit) with the butterfly valves like the Z06 has. Now THAT would be sick.
That is what I am talking about. I wonder how easy such a thing would be able to pull of with aftermarket exhaust parts? And if any aftermarket exhaust companies would even sell such things for our 'Stangs?
JIM5.0 is offline
Old 04-17-2011, 01:28 PM
AzPete
AzPete's Avatar
No reason why one couldn't take the picture to a good shop and have the side exit duplicates....or real close. Car really only needs one set of exhaust exits. I really wonder how much exhaust really "flows" thru that 90* bend it would have to make.
AzPete is offline
Old 04-17-2011, 02:44 PM
JIM5.0
JIM5.0's Avatar
According to fluid dynamics, not the majority of gases go down it.
As with anything, gases will take the path of least resistance and straight through is less resistant than a 90degree turn.
Now, if you factor in the zigzag path the gases must flow through a stock can muffler of a GT, that is a different story.
JIM5.0 is offline
Old 04-17-2011, 03:37 PM
daredevil95
daredevil95's Avatar
Everything is pretty much out there to be bought to complete the job.....the end result would probably be better then the LS Boss exhaust. I would have to take all the collected parts down to an exhaust guru and pay to have him piece it together. And yes, I would delete the back exhaust....side exhaust only!
daredevil95 is offline
Old 04-17-2011, 03:43 PM
ShaneM
ShaneM's Avatar
that's what i mean, butterflies are coming for the boss that are supposed to send the exhaust in its entirety out the side pipes.
ShaneM is offline
Old 04-17-2011, 03:50 PM
daredevil95
Here's a cheapo Electronic exhaust valve.....save yourself the pain of climbing under the car to remove the block-off plates.
http://www.alibaba.com/product-gs/44...t_Kits3_2.html
If we spent some time looking around there may be a complete Mustang Kit already available...there has to be and if not...it's easy enough to create.
Old 04-17-2011, 07:02 PM
SpartaPerformance
SpartaPerformance's Avatar
Originally Posted by daredevil95
I like it along with the finned rear end cover and brake ducts. I would get rid of the 2 pc DS for a lighter unit. The pic is interesting....70K is outrageous!!
Sticker on a BOSS is $45k with a couple options the Laguna Seca package is $2,500 more. Nobody whould eb paying anywhere near 70k
Originally Posted by JIM5.0
Do you all think the secondary side exhaust system would ever become available through FRPP for the normal GTs?
That would be great to have electronic cut-outs for the side exhaust so you could switch from full rear to side exhaust with a push of the button!
I think Borla is still the OE exhaust manufacturer for the Mustang, I'm sure they'll have some kind of kit available sooner or later.
SpartaPerformance is offline
Old 04-17-2011, 08:40 PM
ShaneM
ShaneM's Avatar
boss starts at $40,995, the laguna seca package is a $6995 option. Only 500 of those LS cars getting built and it seems most are gone are stuck with stupid mark ups.
only options on the boss at all are the recaro seat and torsen diff at $1995 and the boss floor mats and car cover for $475. the only LS option is the car cover and floor mats.
You can buy every part you need to turn your normal boss into a LS car other than the rear seat delete which is apparently not offered. scuttlebutt says that the small company that makes it for ford couldnt keep up so it was removed from the FRPP catalog. I sort of wonder if that is the reason the LS was so limited in number since that seat delete is the key component other than different dampers and other suspension bits that separates the LS from the normal boss.
ShaneM is offline
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
UrS4
09-30-2015 10:13 AM
GT350 S550 Tech
09-29-2015 03:29 PM
Quick Reply: Boss 302 Laguna Seca Underneath
