Sponsored by:
Sponsored by:
Torque and spacers for rear control arms
Old 05-11-2011, 08:29 PM
92hatchLX
92hatchLX's Avatar
Default Torque and spacers for rear control arms
What are the torque specs for the rear control arms (upper and lower). Also there were 2 smaller spacers and 2 larger spacers. We figured out where the two larger spacers went but were clueless as to where the two smaller ones went. Everything went back in like stock so we just left them out. Test ride was fine. The rear end feels good and tight now. I can't wait to launch this beast and see how it feels with no wheel hop.
92hatchLX is offline
Old 05-11-2011, 09:17 PM
05xrunner
05xrunner's Avatar
my UMI install sheet said 129lbs for the lower control arm bolts..I am guessing the spacers are for the upper control arm..I didnt replace that only my lower control arms and panhard bar and I had no spacers with those.
05xrunner is offline
Old 05-12-2011, 12:46 AM
stealth_GT
stealth_GT's Avatar
I zapped my lower control arm bolts with an 1/2 inch impact gun. Remember to compress the shock to ride height. You can torque down the bolts if you want but it's a pain.
stealth_GT is offline
Old 05-12-2011, 01:56 PM
92hatchLX
92hatchLX's Avatar
Well for future reference the control arms torque to 120 ft lbs. If you buy the UPR control arm kit, you don't need the small spacers for the 2011+.
Old 05-13-2011, 09:49 AM
Riptide
Riptide's Avatar
What type of bushings are on these arms? The stock specs are 129 ft. lbs. for control arm fasteners.
If you are using UMI roto-joints I would definitely not go that far with them. 100 ft. lbs. is it. You go further than that and you can crush those spherical joints. I destroyed two of mine by over-torquing and I only took it up to 129.
Riptide is offline
mtgldr
02-03-2024 09:00 PM
GimpyHSHS
09-18-2015 12:27 PM
Dragonus18
09-09-2015 01:21 AM
09-08-2015 11:50 AM
M3hunter
09-05-2015 03:42 PM
Quick Reply: Torque and spacers for rear control arms
