FI Guys, care to post your gauges?
I meant Autometer in the OP, not Roush. I need cold air on me all the time, and if I can't make it blow towards me that might bother me. Unless I just used those for the middle two vents and left the driver vent for myself. either way, thanks for all the pics so far guys.
thanks.. I didn't personally install it, George @ Brenspeed did it for me, but I was there and with the Raptor shift-light it wasn't too terribly bad, just pull the vent bezel and vent louvers and cluster bezel out and just running wire, ground wire, power wire and tach output lead wire (or the switched side of the ignition coil). 3 wires.. the mount bracket is dbl-sided taped in (its not coming off - thats some heavy duty stuff and the shift-light is very light-weight)
I've actually watched several of yours. I have looked all over youtube for a s197 with vortech so I can get an idea of the idle sound as well as the in-car acceleration and your vids have some of both.
On the other side, I'm not very good with wiring, but that doesn't sound too hard.
Is there an air vent pod that allows you to adjust what direction the AC blows since ROUSH's does not?
I LOVE the look but here in West Texas the AC and having it the way you need it is
um... IMPORTANT lol!
