Remote Start and the car shutting off when you open the door?
I don't have remote start, but I wouldn't want it to shut off once you open the door for the simple fact that everytime you start your car, it can cause unnecessary wear and tear on the engine/starter. I could be way off base, but I thought i remember hearing that the majority of wear on your engine occurs during the starting.
We have 2 vehicles with remote start, they stay on until you get in and hit the brake pedal with out having the key in. There is no reason to have them turn off when you open the door, that would really suck in Wisconsin winters. One does time out in 10 minutes, so if you don't get back to it in 10 minutes it will turn off.
From what I can tell, the reason it shuts off when you open the door is because of the "my key" feature. The car has to see a key when it's remote started, to avoid problems with the different settings of the keys it will make you start it again with your key so your settings are applied.
Yeah I've heard about that. I wonder if it's an easy fix. I read something about it disabling the MyKey feature if you remedy the car shutting off problem, but I don't even NEED MyKey. There are no kiddies at my house.
I imagine that another layer or two of electronic complexity could solve that possibility, at some risk of it faulting to not letting you drive away in it either.
Norm
