Sponsored by:
Sponsored by:
Is it ok to return CATS after deleting them?
Old 04-21-2012, 10:06 AM
Q8 GooGles
Q8 GooGles's Avatar
Default Is it ok to return CATS after deleting them?
Hello.
I bought an '05 Mustang GT around a year ago and it had no cats + Flowmaster mufflers.
Where I live they are very strict about car modifications so I decided to just return the car back to stock.
I asked several people about this and mostly what I got was it's not recommended to put the cats back on a car where they were removed before because it will affect the car's performance. How right is this statement? And would you guys recommend I put the cats back on + stock mufflers or just get the stock mufflers?
Also, when I say "affect the car's performance" I mean it would drop to below what it was before when the car originally had the cats on.
Q8 GooGles is offline
Old 04-21-2012, 11:30 AM
99GTvert
is my username.
99GTvert's Avatar
Do you know if the car has the stock tune on its computer? If it was tuned for the no cats exhaust then putting cats on it again with the no cat tune might make the car's performance worse than when it was stock but otherwise if the tune is the original, from the factory tune then I don't understand how it would be worse.
99GTvert is offline
Old 04-21-2012, 05:38 PM
Q8 GooGles
Q8 GooGles's Avatar
Thanks for your answer
Old 04-21-2012, 06:09 PM
Nuke
Nuke's Avatar
If it has no cats and isn't throwing a code then I have to assume that the previous owner more than likely had a custom tune to turn off the O2 sensors. Putting the cats back on won't hurt anything but you'll lose a few minor RWHP and also quiet the exhaust slightly. However, the O2 sensors will still (presumably) be turned off. Depending on how emission testing is done in your area, that may still cause a problem.
Nuke is offline
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
09-24-2015 09:18 PM
Quick Reply: Is it ok to return CATS after deleting them?
