Sponsored by:
Sponsored by:
live axel
Old 04-30-2012, 06:17 PM
sanfan
sanfan's Avatar
Default live axel
Hello everyone,
I have a 2012 GT 500 with 700 hp,
How can i replace the live axel for amething better so the back of the car want hup aroung so much.
Thank you,
sanfan is offline
Old 04-30-2012, 06:35 PM
Warpig12354
Warpig12354's Avatar
You can't replace the live rear axle with IRS if that's what you mean. You can get a Torsen differential that's in the Boss 302, it may help. You can also upgrade your suspension i.e. LCA's, sway bars, shocks, struts, etc. Otherwise... troll away
Warpig12354 is offline
Old 04-30-2012, 06:59 PM
Alec
Alec's Avatar
I'd upgrade the diff, clutch packs for the power levels and suspension to put that power down
Alec is offline
Old 04-30-2012, 07:29 PM
X3xMONGOOSEx3X
X3xMONGOOSEx3X's Avatar
Should have bought a stock 03-04 Cobra.
X3xMONGOOSEx3X is offline
Old 04-30-2012, 07:49 PM
moosestang
moosestang's Avatar
You need to be more specific. Are you experiencing wheel hop in a straight line or is the problem when cornering?
There is nothing better than a live rear axle for big power. A 03-04 cobra would be breaking half shafts and has worse wheel hop.
moosestang is offline
Old 05-01-2012, 07:17 AM
sanfan
sanfan's Avatar
if the road is not complitly smoth then the back is hoping, i'm locking for something that will make the back stock to the road.
sanfan is offline
Old 05-01-2012, 11:04 AM
Alec
Alec's Avatar
Check out a set of lower and upper control arms. I have the UMI poly/roto LCAs with welded in relocation brackets and it eliminated wheel hop. Different power levels, but still...
Alec is offline
Old 05-01-2012, 11:24 AM
replica
replica's Avatar
Watt's Link?
replica is offline
piotrek53
10-13-2015 06:54 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
GTJIM
09-23-2015 09:59 AM
03blackwidow
09-20-2015 02:36 PM
Quick Reply: live axel
