Sponsored by:
Sponsored by:
Broke a bolt.. cheapest replacement?
Old 07-11-2012, 08:24 PM
conor1148
conor1148's Avatar
ok. my eyesight isnt good enough, but I got a better set of eyes to look at it and she said it says "10.9" and "eta" and the rest she cant read. i can get that at an ace?
I feel really stupid that I haven't already learned about this.
conor1148 is offline
Old 07-11-2012, 08:50 PM
xkape
xkape's Avatar
grade 10.9 is an alloy steel bolt, quenched and tempered. I have no idea what the hell ETA is. Its also means its metric
xkape is offline
Old 07-11-2012, 08:52 PM
xkape
xkape's Avatar
ok quick search of the old intraweb and I got this
Even among professionals, the ETA is not particularly well known. One of the reasons is the complexity of the system; the ETA for metal anchors consists of 12 alternative options. Each option consists of a certain amount of tests to be performed on the product. In option 1, many different properties of the product are tested, whereas in option 12 just a few properties are tested. This means that products in option 1 have much more official data available on their properties than those in option 12. In other words, an option 1 product is more transparent in terms of its possible range of applications.
xkape is offline
Old 07-11-2012, 08:53 PM
BigDinTexas
BigDinTexas's Avatar
Is there a Fastenal near you? You could walk into their storefront and get the bolt you need in a flash.
Don
BigDinTexas is offline
Old 07-11-2012, 09:23 PM
conor1148
conor1148's Avatar
Don
I have one close to me, do i still need to figure out a part number?
Old 07-11-2012, 09:35 PM
99gtstang
99gtstang's Avatar
Good to know...
OP must be hulk to break that bolt!
99gtstang is offline
Old 07-11-2012, 09:40 PM
conor1148
conor1148's Avatar
Originally Posted by 99gtstang
Good to know...
I barely applied any pressure and it snapped! makes me really nervous about the rest of the caliper bolts. I think the car has been through it's 3rd brake pad change so I guess it was just it's time to go.
Old 07-11-2012, 10:41 PM
BigDinTexas
I wouldn't think so, since the P/N you get from Ford might not correspond to Fastenal's part numbers... Just take the bolts you have with you and they can identify them from there.
Don
Old 07-11-2012, 11:57 PM
JThor
JThor's Avatar
The bolts may be suffering from heat fatigue. Bolts are not really expensive. Since you're doing a brake job (I assume), I would replace the set. 4 bolts can't be that expensive. Better to be safe . . .
JThor is offline
Old 07-12-2012, 09:44 AM
MiniD
MiniD's Avatar
It's not always about the strength of the bolt. Some bolts are specifically chosen to be softer than what they are screwing into so that they break before threads get stripped or to prevent galling. With all but the most generic fasteners, it's better to get them from the dealer, at least for newer cars and specialty components.
MiniD is offline
Quick Reply: Broke a bolt.. cheapest replacement?
