Sponsored by:
Sponsored by:
Broke a bolt.. cheapest replacement?
Old 07-11-2012, 07:18 PM
conor1148
conor1148's Avatar
Default Broke a bolt.. cheapest replacement?
conor1148 is offline
Old 07-11-2012, 07:26 PM
xkape
xkape's Avatar
Yes, so to replace it, go find the cheapest bolt you can which is made out of the cheapest material possible. Then when you have to brake to save your life at force, it can snap in half and fail. What could have saved your life just killed you.
At most a bolt is going to cost you like $10 bucks dude. Seriously, I am not trying to be a dick, I'm trying to make a point. When it comes to safety, don't short yourself. It's how you end up dead.
xkape is offline
Old 07-11-2012, 07:38 PM
conor1148
conor1148's Avatar
no need for all the sarcasm. I'm not trying to ask you if I should go to lowes or ford.
But thank you, I will go to ford tomorrow.
Old 07-11-2012, 07:42 PM
xkape
xkape's Avatar
There was no sarcasm.. I was being pretty straight forward for an example. I would MUCH prefer you to live and enjoy your life and that Mustang than to cheap out on something and end up dead because of it.
xkape is offline
Old 07-11-2012, 07:44 PM
xkape
xkape's Avatar
Lowes sells bolts just as strong and stronger than Ford. Check that bolts specs and just make sure you meet or exceed its grade.
xkape is offline
Old 07-11-2012, 07:47 PM
conor1148
conor1148's Avatar
I'm looking for the part number now. I should be fine bringing them a part number and bringing the bolt pieces to make sure it's same, right?
Old 07-11-2012, 07:50 PM
xkape
xkape's Avatar
theres usually a number on the head of a bolt telling you the grade. From there you just need to make sure you get the correct lenth of the bolt and the thread pitch right. But yes, definately a Lowes employee in that department would be able to tell you those things by seeing the bolt.
Don't know how to find them myself but if you search or wait for someone else to post, I am sure they will post the Ford spec sheet for that whole assembly and you can use it as a guide. You probably stripped the bolt head off by torquing it too far above spec. That sheet will tell you the correct torque as well
xkape is offline
Old 07-11-2012, 08:05 PM
99gtstang
99gtstang's Avatar
Take that bolt to a part store and try to fit it. They will have a plate with threaded holes to check fit and buy some grade 8 bolts.
If it's jacked up that bad, pull one from the other side so you have a full size bolt.
99gtstang is offline
Old 07-11-2012, 08:12 PM
conor1148
conor1148's Avatar
I think i found the part number, I'm just going to go to ford tomorrow so i can be 100% sure i get the right thing.
Old 07-11-2012, 08:17 PM
slyter485
slyter485's Avatar
This. If you can find the bolt diameter, length, and thread pitch, you can take it to an Ace Hardware and get plenty of replacements for 1/2 the price, and still keep strength integrity in the bolts you buy.
slyter485 is offline
Quick Reply: Broke a bolt.. cheapest replacement?
