Sponsored by:
Sponsored by:
What's the best way to get oil off my car?
Old 11-07-2012, 11:59 AM
ghunt
ghunt's Avatar
Default What's the best way to get oil off my car?
Sometime in the last few weeks I apparently ran through some oil on the highway or on a road somewhere, and it threw it all up on my rocker panel and rear quarter. I have bug & tar remover but it's this thick gel stuff that's made more for spot treatments. If I just wash the car and use good soap will that suffice? The oil has dirt in it and almost looks like it would just wipe off, or at least it kinda does with my finger, I just don't know how much residue it would leave.
ghunt is offline
Old 11-07-2012, 12:55 PM
mmdpg
mmdpg's Avatar
I've found Simple Green to be a really good degreaser. Spray it on, let it soak in for a few minutes then rinse it off. Make sure all of the grit is gone with most of the oil before hand washing the area with auto wash soap and water.
Simple Green also works really well at removing brake dust from wheels and tires.
mmdpg is offline
Old 11-07-2012, 01:21 PM
05xrunner
05xrunner's Avatar
CarPro TarX
or you could try Stoners Tarminator if you can find it locally. I will say from experience TarX works MUCH better at any type of grease/adhesive/tar then tarminator.
05xrunner is offline
Old 11-07-2012, 03:11 PM
ghunt
ghunt's Avatar
Hell, I wasn't even thinking...I've got a whole bottle of Purple Power sitting on my shelf! I'll try that stuff first I think.
ghunt is offline
Old 11-07-2012, 03:13 PM
Mach2
Mach2's Avatar
Spray the area with WD-40, then spray it on a soft rag and wipe the area. Should take care of it. If you ever get gum splattered on your car, WD-40 works great on that too. Used to have a 32 highboy roadster, painted black. Went to go for a scoot one day and noticed pink bubble gum all down the side of the body. Remembered I'd read somewhere where WD-40 works, tried it and it worked great.
Mach2 is offline
Old 11-07-2012, 03:29 PM
siggyfreud
siggyfreud's Avatar
A good dish soap should break up the oil and be okay on the paint. You'll want to re-wax after, as it will also break down the wax. WD-40 is kinda oily in itself, so not sure that would give you the results you're looking for.
siggyfreud is offline
Old 11-07-2012, 03:33 PM
GhostStrykre
GhostStrykre's Avatar
i read something similar before. Dawn dish soap is used in oil spills regions to clean wildlife of the oil, so no reason it won't work on your car. make sure to rewax, as was stated.
GhostStrykre is offline
Old 11-07-2012, 03:55 PM
Goldenpony
Goldenpony's Avatar
Plain old kerosene works great
Goldenpony is offline
Old 11-07-2012, 04:12 PM
Mach2
Mach2's Avatar
WD-40 is oil, and it works great removing oily bi-products picked up from the road. WD-40 will not hurt your paint finish. Try in on a small area first, you'll see.
Mach2 is offline
Old 11-07-2012, 05:04 PM
siggyfreud
siggyfreud's Avatar
I don't disagree, but it would seem you'd still need to soap/wash the WD-40 off, as it won't leave a clean finish. Why not cut out the middle man and just use Dawn and warm water?
Quick Reply: What's the best way to get oil off my car?
