Brenspeed B326 Install
#21
The engine now consists of:
·Brenspeed B326 Shortblock – 9.8:1 Compression
· SVT BOSS 5.0 Cleveland Iron Block – 3.700 bore
· CP Forged Pistons & Rings
· Manley Stroker Connecting Rods w/ARP 2000 Bolts
· Kellogg Forged 3.800 Stroke Crankshaft
· 2013 GT500 Oil Pump
· ATI Super Damper
·FRPP Stage 1 CNC Ported Cylinder Heads
· Comp Cams Beehive Valve Springs/Retainers
·Brenspeed Detroit Rocker Blower Grind Cams - .450 Lift
·Edelbrock E-Force TVS Supercharger/2.75” Pulley (14-15 PSI)
· 2013 GT500 Intercooler Pump
· AFCO Heat Exchanger w/ Dual 10” Spal Fans
· Brenspeed Dyno Tuned (street) – 93 Octane
Could have gotten even bigger numbers with Stage 3 heads, bigger cams and bigger injectors, but since this is my daily driver, we went conservative to preserve driveability.
The Torque is simply unbelievable, even when not in boost. The torque comes in low, right around 2k rpm, which is perfect when cruising (even in OD) and you need to pass a slowpoke or something. You do not even need to downshift or kick it down. It just pulls like a freight train.
Under boost, it is scary fast. She will break the tires loose at any speed. I really need some MT's.
· ATI Super Damper
Whenever I do my build I'm already planning on beefing up the clutch because I'm sure the stock clutch will go quickly with that power. I am wondering how well the transmission and rear end will hold up though.
#22
She is an automatic. I replaced the input shaft with a Level 10 shaft. I also put in a Precision Industries 3200 rpm converter and run a PA deep pan and a JDM catch can.
You will definitely need to upgrade your clutch and you will have to replace your flywheel anyway(Kellogg crankshaft is 8 bolt, your stock is 6 bolt). Your rear should be fine unless you have done (or will do) alot of burn outs LOL.
#23
I did not mean to start a big debate about which engine builder is best. Just sharing my experience, which was great. Like I said, there may be other short blocks out there that may be just as good and/or cheaper. I have nothing against JDM, they build some good stuff and I have dealt with them before (and they are alot closer to me) - but there is no replacement for displacement, which is why I went with a 326.
I am totally satisfied with the B326 build, just as I have always been with everything I have gotten from Brenspeed. This was the first time I ever had them install anything, as I usually do it myself. But when it came down to installing basically a whole brand new engine, I just don't have the facilities anymore to do it (plus this is my daily driver and I can't have it down too long). Great customer service is rare these days, and Brenspeed has always delivered for me.
09-10-2015 08:39 PM
