Sponsored by:
Sponsored by:
2011 GT fog lights won't work.......
Old 04-30-2013, 04:32 PM
ventagemod67
ventagemod67's Avatar
Default 2011 GT fog lights won't work.......
The past couple of days I have noticed my fogs are out. Bulbs, fuse, and ground are good. I have read about a relay, but can't find it. I have also read the light switches go bad, but everything else with the switch works. ( parking lamps, headlights, dimmer switch) Any help would be appreciated....
ventagemod67 is offline
Old 04-30-2013, 05:20 PM
edwin108
edwin108's Avatar
Are your high beams on? Try toggling the high beams off and on while the fog light switch is on.
edwin108 is offline
Old 04-30-2013, 09:43 PM
ventagemod67
Forgot to add that.. highbeams not on...
Old 04-30-2013, 11:23 PM
Art161
Art161's Avatar
Is the ignition switch on? If the 2011 is the same as the 2007, the fogs only work if the ignition switch is on.
Art161 is offline
Old 05-01-2013, 12:58 AM
ventagemod67
Ignition is on, car is cranked, parking brake down, hood down, doors closed... still nothing
Old 05-01-2013, 07:40 AM
edwin108
edwin108's Avatar
Does the orange fog light indicator light up on the headlamp switch when you turn the fogs on? Also, do you hear any relays clicking when you pull the switch?
edwin108 is offline
Old 05-01-2013, 08:48 AM
Andy13186
Andy13186's Avatar
do you have less than 36k miles? if so, just take it to the dealer and they will diagnose and warranty it and give you a loaner if you need. Even if you have more miles i would probably still try to get them to fix it for free.
Andy13186 is offline
Old 05-01-2013, 08:41 PM
ventagemod67
If the orange light does not come on... is it the switch or the relay?
Old 05-01-2013, 08:42 PM
ventagemod67
The car has 14k on it... I was just trying to avoid the hassle. If I can't figure it out.. it'll have to go to the dealer
Old 05-01-2013, 09:28 PM
edwin108
edwin108's Avatar
I would think its the switch; do you hear any relays clicking when you pull the switch?
edwin108 is offline
Quick Reply: 2011 GT fog lights won't work.......
