Sponsored by:
Sponsored by:
Guess it's ball joint time...ugh
Old 09-04-2013, 06:12 AM
ghunt
ghunt's Avatar
Default Guess it's ball joint time...ugh
Went to get my car inspected yesterday with 70K on the odo and they told me my passenger side ball joint was bad (well, and let me wiggle the tire to feel the play), and quoted me $377 to replace it. Ha, no. For as much as Ford brags up on these sealed ball joints they sure seem like crap, I've had issues with them on every vehicle I've owned that had them! Ordered some MOOG ones with a proper grease fitting last night, guess I gotta get to that sometime soon.
Here's a question I did have, if anyone has replaced their ball joints...do they press out from the top, or bottom?
ghunt is offline
Old 09-04-2013, 07:19 AM
Nuke
Nuke's Avatar
Get a 2nd opinion.
Nuke is offline
Old 09-04-2013, 07:34 AM
petrock
petrock's Avatar
I’m not sure if they press in from top or bottom on your ride. On my wifey’s ’98 they press in from the bottom. It should be pretty easy to find out though. Just take a look at the ball joint in the control arm. If the top is wider then the bottom then it presses in from the top. If the bottom is wider then the top, then it presses in from the bottom.
You can rent a C-Clamp style ball joint press from various auto parts stores. You get your money back when you return it. Pretty simple to use with a 1/2” ratchet or braker bar. Even easier with an impact wrench.
petrock is offline
Old 09-04-2013, 09:46 AM
hootie_john
hootie_john's Avatar
For that, you can get replacement LCA with the upgraded ball joints. Or you can go with the Steeda X5 or whatever....don't replace with the Ford stockers.
hootie_john is offline
Old 09-04-2013, 11:24 AM
ghunt
ghunt's Avatar
It definitely had play in it, didn't see much sense in getting a second opinion. Plus a google search told me that these early S197's had ball joint issues. Like I said I ordered some Moog ball joints ($80 for both sides) and plan to rent a press and replace them, I did ball joints on my old F250 a couple years ago and it was a lot older and rustier than this thing so it shouldn't be too difficult.
ghunt is offline
Old 09-04-2013, 02:45 PM
roegs
roegs's Avatar
Most just upgrade to the GT500 lower control arms. They are supposed to have a beefier lower ball joint. My ball joints are bad and I have a set of GT500 lower control arms in the garage waiting to be installed.
roegs is offline
Old 09-04-2013, 05:37 PM
Goldenpony
Goldenpony's Avatar
Default GT 500 LCA
Hey roegs,
How much did these LCA set you back?
Goldenpony is offline
Old 09-04-2013, 05:52 PM
roegs
roegs's Avatar
I bought them back in May for $264.00. Part number is M-3075-E. I get all my FRPP stuff from Tousley Ford Parts. Their prices are very good and I've had excellent customer service from them.
roegs is offline
Old 09-05-2013, 04:03 AM
Lem-06
Lem-06's Avatar
I bought a steeda bump steer kit when I lowered my car, the stock pieces are removed quiet easily via removing the nut, and gently tapping the end of the bolt and it will drop out of the bottom, then just slip the new one into place and torque it up
Lem-06 is offline
Old 09-05-2013, 09:48 AM
ffk_pennywise
ffk_pennywise's Avatar
I had to replace my stock ball joints at 60k. I used the Moogs and they are still going strong at 140k miles. Sorry i don't remember which way they came out. Its been a few years.
ffk_pennywise is offline
Quick Reply: Guess it's ball joint time...ugh
