Sponsored by:
Sponsored by:
13' bad wheel bearing already?
Old 02-14-2014, 11:16 AM
jz78817
jz78817's Avatar
which tires do you have?
usually a bad wheel bearing will get louder when you're turning left/right, not quieter. Believe me, I had an SRT-4; I know what bad wheel bearings sound like
jz78817 is offline
Old 02-14-2014, 11:48 AM
tbear853
tbear853's Avatar
Originally Posted by '13GT Black
I purchased a '13 GT last year. I'm not sure if this noise was there before as I drive 9/10 times with the window down. It sounds like a bad wheel bearing but in city driving its only noticeable between 40-60mph. To diagnose it, I jacked it up to check for any play but didnt find any. I also swerve it left and right while driving but the noise does not go away nor does it get quieter.
I found a video that has the sound I'm talking about below, it starts at 5:14, that "wom wom wom" sound. Does your '13 GT sound like that driving?
Don't have a '13 GT, but tires will do that, all it takes is a wear pattern to start because of a small imbalance that is tolerated or simply not felt (rear axle maybe and then get rotated to front) and it usually never reverses itself, but can be re-balanced and put on rear and may then be less noticeable. You can try rotating the suspected tire with another and see if noise goes with it.
tbear853 is offline
Old 02-14-2014, 02:02 PM
Derf00
Gentleman's Relish
Derf00's Avatar
a wom wom wom sound is usually a tire issue as a bad part/patch of the tire comes around and makes contact with the road surface. A bad bearing would be constant noise, not wom wom wom. 40-60 mph is the harmonic frequency of most tires...meaning, if you have an imbalance problem it should show up at those speeds.
Check out the front tires and rotate them. When you have them off the car, be sure to roll them to see if you find any flat spots or spots where the tread doesn't look right. that will be the culprit.
Derf00 is offline
Old 02-14-2014, 09:25 PM
13'GT Black
13'GT Black's Avatar
It might be the tire wear, front tires are wearing more in the inside compare to the outside tread. My alignment is within spec for camber and toe, dont know why its not wearing evenly. If its the tire wear noise why would wom wom wom noise come only from the driver front area? engine noise? Thanks everyone for helping
13'GT Black is offline
Old 02-15-2014, 06:23 AM
jz78817
jz78817's Avatar
because that's where you're sitting?
jz78817 is offline
Old 02-15-2014, 09:01 AM
157dB
Cut & Paste Expert
157dB's Avatar
Ride it the trunk with someone else driving and see if the
woooom wooommm wooommm is there as well??
I see it as being tires or road surface noise.
157dB is offline
Old 02-16-2014, 02:01 AM
tbear853
tbear853's Avatar
tbear853 is offline
Old 02-19-2014, 02:47 PM
Derf00
Gentleman's Relish
Derf00's Avatar
it's possible that only that tire is having issues.
Rotate the tires, see if the sound moves. If it does, then wherever the tire moved to that the sound followed, it's that tire. If it doesn't, then worn suspension or bad alignment is the next possible culprit.
Bad suspension (struts or strut mounts) causes cupping of the tires. If it's bad enough, the tire will bounce as it rotates at 40-60 mph you would also get a wom sound.
Derf00 is offline
Old 02-19-2014, 03:31 PM
RazorGT
RazorGT's Avatar
it is weird though, 2013 and already having this problem?? why do you guys think that is?
RazorGT is offline
Old 02-19-2014, 06:43 PM
tbear853
tbear853's Avatar
All it takes is a bit of dynamic imbalance (not same as static imbalance) or even occasionally, a bad tire.
tbear853 is offline
Quick Reply: 13' bad wheel bearing already?
