Royal Purple vs Amsoil, and what's synchromesh?
The title sums up my questions pretty well.
I currently have 1,200 miles on my 2014 Mustang GT (manual).
1. I was debating between Full Synthetic Royal Purple versus Amsoil 5w-20 (cap recommended).
2. Then I looked up manual transmission oil and see Synchomesh (5w-30) and other special manual oils, another example is Transaxle Gear Lube 75w-90.
Should I be using special manual oil like Synchomesh or should I stick the regualr oil?
Oil I was going to buy or same but in Amsoil
when in doubt, read your manual.
Agreed, I feel like royal purple is overkill and more of a thing to brag about rather than actual efficiency, I usually like to keep things as OEM as I can unless the OEM part is faulty in which case I get a upgraded version from a third party.
Thank you for the responses. Yeah, I was reading online and it sounded like motor and transmission oil were the same. Guess not, how often do I change my transmission and differential oil? Are there mustang how-to videos on this forum?
As an example, countless numbers of Chrysler A604/41TE transaxles were trashed because people just assumed they took bargain basement Dexron III instead of the ATF+4 they required.
