Info on fuel trims
I went to get inspection an hour ago and check engine light hasn't been on for two days I drove car for 180 miles and still doesn't pass monitors are still staying o2s not ready,heat circuit not ready,cats not ready,and egr not ready don't no what else to do they told me to keep driving it I don't thing that's going to fix it also high side fuel trims are at 28%
Did you upgrade your injectors and fuel pump/system when you got the supercharger installed? If not, that's where I would be looking if you can't find a vacuum leak...
No exhaust leaks? I would assume your wide band is correct and you have way to much oxygen in your exhaust. Either it's really running that lean at WOT or you have and exhaust leak before the wide band that's letting oxygen in. I wouldn't be using full throttle till you figure it out.
Time to pull the spark plugs, are you sure they are all firing? Stock coil packs? I had an aftermarket coil pack that crapped out and it didn't set any codes except a lean code. the air/fuel wasn't burning from that cylinder at WOT, so all that oxygen was seen as a lean condition. Car idled fine and ran good, but WOT was crappy.
That's why I'm thinking it's his fuel system. The fuel trims are trying to compensate for something like a pump going bad by increasing injector duration.
Check your fuel pressure and flow. Could very well be that your pump is going out. That's why I plan on doing the Ford Racing dual fuel pump kit if I ever FI my mustang.
Also, something could be bad in your O2 sensor system causing your car to stay in open loop mode, and the open loop fuel calculations/map could be wrong for your setup. I would check your pump first, but check and make sure that your O2 sensors are working properly after.
Do you have a multimeter? You can check the resistance of the heater circuit for the bank 1 upstream sensor to see if its dead. If I'm reading the wiring diagram correctly, the wires for the heater circuit are a green-brown wire and a violet-gray wire.
