harmonic balancer wobble, replace?
I zoomed in and slowed the video down to 1/4 speed to make it more noticeable. just looking at it from above you can tell there's a slight wobble to it. The rubber is not perfectly flush all the way around, but I think it's been that way for a long time.
Should I replace it? A new stock one is only $39 from new takeoff. Next question is, where's the how to writeup? I know you need a pulley puller, but what about the installation tool, necessary?
I'm going to use this method to remove the crank bolt. If scotty kilmer can do it, then I surely can.
I can brace my breaker bar against the underside of the frame. Pull the fuel pump fuse so the motor won't start and one bump of the key should do it.
If you look at the UDP install guide it helps. I know you have to rent a Chrysler pulley remover. But in some of them the arms arnet long enough!! So I took a 3/4 (or maybe it was a 5/8?) socket and very carefully placed it to where it wouldn't damage the crank, you have to be slow and gentle. I also know the main crank bolt is one time use only so gonna have to get one a 9.00 bolt I think! If it was me I would take the three surrounding bolts and the new crank bolt and re torque them to spec. The wobble may just be in your head? It doesn't look too bad to me. But if it bugs you hey why not?! Also high temp silicone for the key slot required too..
http://m.mustangforums.com/forum/sho...6023&styleid=9
Here is a good write up. Obviously you don't have to do it all if your not doing the UDP but you may as well it helped free up a couple hp for me! Felt like turning the AC off when it was already off. (That's the best way to describe the feel) just remember the socket you'll need with the Chrysler pulley.
As mentioned you need a chrysler style puller. I used this puller when I removed mine http://www.summitracing.com/parts/otc-6667/overview/ Also I would definitely use an installer tool to push the new balancer back on as you risk pulling the threads out of the crank just wrenching it on with a bolt. I used the method that guy does in the video to loosen the bolt as well. Pretty easy job over all.
Seen that happen before.
