Sponsored by:
Sponsored by:
Stripe Advice and Mods On *Pic Heavy*
Old 05-29-2014, 04:54 PM
Tanner05
Chop Mod
Tanner05's Avatar
Default Stripe Advice and Mods On *Pic Heavy*
I just got my car back from the body shop with a BMC black mamba hood and SHR louvers. I bought a gloss black Super Snake stripe to go on at the same time, but the shop didn't install it. So now I have to make up my mind if I want it on.
So stripe or no stripe? Also, my husband is wanting to try putting the stripe on. He's mechanically inclined, but he's never worked with vinyl. Any tips? How hard is it to install a stripe?
Tanner05 is offline
Old 05-29-2014, 09:56 PM
steel pony
steel pony's Avatar
it's not that hard actually....you have LOTS of flat spaces to work with, being it's a coupe.
Your toughest tasks will be tucking the stripes on the front bumper and working the angle to make sure it stays even. If you bought a stripe kit, then it will be THAT much easier.
since your car is white, there are some things that need to be done prior to laying the stripes.
#1 CLEAN, CLEAN, CLEAN the car! Claybar and iron-x it as well. You won't have to worry about the hood since it's freshly painted, but the rest of the car needs to be as spotless as possible! You want absolutely no dirt trapped between the vinyl and the paint, especially on a white car. If you ever remove the stripes, you don't want to find rust spots or erosion from not cleaning it in the first place. Iron-X will lift and remove any remaining rail dust from the car, and is recommended for light colored cars (especially white) prior to striping.
Once you're done with that, then it's on to the stripes!
#1 ALWAYS lay stripes on a cool, clean surface
#2 mix a spray bottle with water and a few drops of Dawn...this will be your lubricant for moving/positioning the stripes.
#3 If you have some of the plastic vinyl squeegee tools, get some felt and glue it along the edge. This will prevent streaking/scratching in the vinyl when setting it to the car, especially if you start overworking it...the softer the contact surface on the vinyl, the better.
#4 TAKE YOUR TIME!
#5 do a flat surface first (like the roof), to get a feel for what you are doing.
#6 use a grease pencil to mark the center of the car, then use painters tape to mark off the gap or edge lines for the stripe.
#7 MEASURE TWICE, THEN MEASURE AGAIN!
#8 TAKE YOUR TIME!
#9 once the stripe is laid...don't mess with it! Let it dry...trapped water and air will work themselves out over a few days or allowing the car to sit in the sun...
I'm sure i'm forgetting something, but if you're patient and just take your time, it will be easier than you think and your car will be transformed from...
THIS:
TO THIS:
steel pony is offline
Old 05-29-2014, 11:10 PM
X3xMONGOOSEx3X
X3xMONGOOSEx3X's Avatar
I don't think it needs it, but I don't think it would detract from the cars look. If you already have the stripes might as well put them on and see if you like the look. It's only vinyl.
X3xMONGOOSEx3X is offline
Old 05-30-2014, 06:25 AM
steel pony
steel pony's Avatar
even if you decide not to put the stripes on, i'd recommend a good cleaning and an Iron-X bath for the car...
here's whats left behind in the paint even after claybar...this is just rail dust and other contaminants still in the clearcoat
Old 05-30-2014, 07:16 AM
drfister
drfister's Avatar
I think that hood flows really well with the lines of your car. Very nice!
I say try the stripes, vinyl can be removed if you don't like the look but the super snake stripes are defiantly the way to go..
drfister is offline
Old 05-30-2014, 10:23 AM
Cruzinaround
Cruzinaround's Avatar
No Tanner...nooooooooo.
Cruzinaround is offline
Old 05-30-2014, 10:30 AM
2005Redfire6
2005Redfire6's Avatar
I wouldn't, Tanner.
2005Redfire6 is offline
Old 05-30-2014, 10:58 AM
Shampue
Shampue's Avatar
I think stripes on an all white car would look very nice.
I've been thinking about white or pearl stripes on my Vista Blue convertible but I can't decide.
Shampue is offline
Old 05-30-2014, 11:02 AM
Cristoff
Cristoff's Avatar
I NEVER thought I would say this --- I agree with Cruzin. I think stripes would take away from the look.
Cristoff is offline
Old 05-30-2014, 12:10 PM
sbradle4
sbradle4's Avatar
no stripes... leave it clean!
sbradle4 is offline
Quick Reply: Stripe Advice and Mods On *Pic Heavy*
