Sponsored by:
Sponsored by:
160 degree thermostat ?
Old 05-30-2014, 11:31 AM
Steven Bannoura
Steven Bannoura's Avatar
Default 160 degree thermostat ?
I am thinking about replacing my thermostat with high quality and 160 degree one. Do you guys recommend it ? i live in NC, so its mostly hot, and i rarely drive that car in the winter anyway.
I also can't find it anywhere, where would i go about finding one that fits and comes with the gasket .
My thermostat isn't bad, but i just want one that runs cooler.
Thanks !
Steven Bannoura is offline
Old 05-30-2014, 11:48 AM
Steve@Tasca
Former Sponsor
Steve@Tasca's Avatar
In my experience modern cars run better with the correct temp stat in them, the PCM is looking for the higher temps when it's adjusting fuel, spark etc.
I doubt it could hurt to try a 160 but I'm not sure there will be any benefit.
-Steve
Steve@Tasca is offline
Old 05-30-2014, 11:53 AM
jz78817
jz78817's Avatar
don't. modern engines are meant to run hotter. don't mess with the thermostat temp just because you think it's a keen thing to do. if you're not overheating you have no problem.
jz78817 is offline
Old 05-30-2014, 01:14 PM
Steven Bannoura
sounds good, cause iam running 200 to 210 in traffic with the AC off, about 190 while moving .
Old 05-30-2014, 02:34 PM
moosestang
moosestang's Avatar
I have a 160, because that is what whipple ships with their HO kit or did. You aren't really going to run cooler unless you change your fan settings. Have your high speed fan come on at 190-195. I think mine is set at 190, so my head temps never get much over 200. My car normally runs 180-190 whiling moving, 170's if it's cool out. It never stays at 160, even when it's in the 30's outside.
A stock motor will hit 220 before the high speed fan cools it back down. Probably runs more efficiently at that temp or reduces emissions. It most certainly reduces power.
What oil are you using?
moosestang is offline
Old 05-30-2014, 02:35 PM
Simon1
Simon1's Avatar
Thanks !
I'm surprised you don't have one already. It's pretty standard with FI to put in the lower temp thermostat. There maybe some tuning that need to be changed with the fans, adjusting high speed and low speed fans, but they can be adjusted with a handheld.
The purpose of the 160 is it helps prevent detonation, don't know why, but it does.
With my turbo and my KB, both came with low temp thermostats. Sure you don't have one already?
Simon1 is offline
Old 05-30-2014, 07:54 PM
CYRUSGT
CYRUSGT's Avatar
This is the one I'm looking to get in a few weeks.
http://www.cjponyparts.com/reische-p...oboost/p/RT50/
CYRUSGT is offline
Old 05-31-2014, 07:39 AM
Steven Bannoura
Royal purple 5w-30
Old 05-31-2014, 07:42 AM
Steven Bannoura
I never replaced it, and iam pretty sure the guys who installed my procharger didn't either
Steven Bannoura
I am surprised they don't have it at amaerican muscle
Quick Reply: 160 degree thermostat ?
