Sponsored by:
Sponsored by:
Sea-Foam Advice Please.
Old 06-09-2014, 01:17 PM
jz78817
jz78817's Avatar
Originally Posted by moosestang
I'd use this instead if you really want to put something through the vacuum line. I don't think it's much different from seafoam, but at least it comes with a fool proof method to get it into each cylinder more evenly.
http://www.amazon.com/Berryman-2610-...+b-12+chemtool
I have a can sitting in front of me right now and I'm going to take a before and after video of the piston tops. I'm betting it doesn't removing any of the burned on carbon.
it's very different from seafoam. This is what it contains:
Ingredient CAS Number Weight
Acetone 67-64-1 <5%
2-Butoxyethanol 111-76-2 10-15%
Ethylbenzene 100-41-4 10-15%
Methanol 67-56-1 <5%
Methyl Ethyl Ketone 78-93-3 <5%
Nonylphenol Ethoxylate 127087-87-0 15-20%
Xylene (mixed isomers) 1330-20-7 40-50%
many of those are already in pump gas. So if pump gas isn't cleaning the "burned on carbon" then I don't see that can o' stuff doing so either.
jz78817 is offline
Old 06-09-2014, 01:38 PM
moosestang
moosestang's Avatar
Acetone 67-64-1 <5%
You have to figure these ingredients are quite concentrated though, compared to how much is in 16 oz of gasoline. I may try some straight windshield washer fluid too, I bought it more for the tube that atomizes the mixture and sucks it in slowly.
Being supercharged, my car runs rich and not just at WOT, so carbon is going to build up.
moosestang is offline
Old 06-09-2014, 01:49 PM
jz78817
jz78817's Avatar
for the love of god, why? what makes you want to feed random crap into your engine?
jz78817 is offline
Old 06-09-2014, 02:31 PM
moosestang
moosestang's Avatar
it's just methanol and water, they make kits to inject this stuff into your motor to raise the octane of the fuel charge.
That berryman is some corrosive ****.
Old 06-09-2014, 04:01 PM
Art161
Art161's Avatar
I don't like to do any maintenance work either shortly before or during a trip. This has to do with anything, not just Sea-Foam. I wouldn't have the oil changed or the cooling system flushed or anything in the way of routine maintenance later than a couple of weeks before the start of a trip.
In the case of Sea-Foam, if you use it at all, IMO it should be while you are close to home. If your car is running okay, and you use quality gas, I don't know why you think you should use Sea-Foam.
Have a good trip.
Art161 is offline
Old 06-09-2014, 05:03 PM
Goldenpony
Goldenpony's Avatar
Default Seafoam?
No thanks. I change my fully synthetic oil every 5K miles and along with that a can of Chevron Techron in the tank at every change. All I need.
Goldenpony is offline
Old 06-09-2014, 07:06 PM
moosestang
moosestang's Avatar
I'm surprised no one has done a simple before and after of these products by putting a $20 borescope video camera down a spark plug hole, I googled it, can't find anything. I'm doing it on Wed., so stay tuned. I all ready think seafoam will do nothing to remove the baked on carbon on top of my pistons and in the combustion chamber, so I won't bother testing it. I will do the berryman b-12 and probably plain old distilled water using the berryman tubing.
Ok, it's now $45, it was $20 something just two years ago and still works great.
Mini 7mm USB Flexible Inspection Camera Microscope Endoscope Borescope: Amazon.com: Home Improvement Mini 7mm USB Flexible Inspection Camera Microscope Endoscope Borescope: Amazon.com: Home Improvement
My piston top 2 years ago. One of the cleaner looking ones.
Old 06-09-2014, 08:47 PM
drewsky
drewsky's Avatar
Keep me posted on the before and after with the piston tops. I'm curious to see this!!!
drewsky is offline
Old 06-09-2014, 09:12 PM
Nuke
Nuke's Avatar
OP, what is the reason you want to do both direct induction and fuel mix with SeaFoam? Unless you have a specific problem and you're simply looking to clean the fuel system, just run SeaFoam or Techron in the fuel system as directed on the bottles directions. I run Techron regularly in all of my vehicles as preventive maintenance at 10k miles or every oil change, whichever comes first. If I suspect an issue, I'll use SeaFoam. Regardless, there's no smoking and you'll never notice it on a cruise.
Nuke is offline
Old 06-10-2014, 12:35 AM
drewsky
drewsky's Avatar
No reason in particular. Just heading towards 85k and wanted a system cleaner. I run fuel injector/combustion chamber cleaner every other month or so. So it seems there really is no big difference between seafoam and that if your running it in your tank. Which I would. My real question was that if this stuff was superior to others when it comes to cleaning carbon build up. I've heard a lot of talk recently on this stuff so it's got me thinking.. Haha.
drewsky is offline
Quick Reply: Sea-Foam Advice Please.
