Not happy with my car right now
You can't expect Ford to deal with your aftermarket radio.
I'm leery that the AC issue is PCM-related. SJB, perhaps, but PCM? Even shooting the contacts on the compressor electrical connectors has been known to solve issues like yours.
As far as the fuel filling issue, welcome to the crowd. There's a TSB on it and even THAT "fix" is known to NOT solve the issue.
Seems like an awful lot of crying and attention seeking.
How is YOUR aftermarket radio Ford's problem? Even a high end aftermarket radio has failures, let alone cheap eBay specials..
For the other issues - stuff happens. That's why this world is covered with tens of thousands of auto repair shops. Things break - and you're no more special than anyone else.
As others have said, those aren't major issues. A bit of research goes a long ways. If you are being charged more than a fair amount from labor, bust out your tools and spend some time with your car.
Reading through some of your other post it seems most troubles have started after the Roush SC install. You had a code p1289 indicating CHT sensor open condition. Has the CHT sensor, connection and harness been checked for opens, shorts, disconnected or being broken during install? Your coolant gauge will probably function normally after this CHT problem is repaired.
When you installed the SC did you solder and heat-shrink all your wiring modifications or just use open crimps. Any wiring repairs in an engine compartment or outside weather conditions need to be heat-shrink covered to prevent corrosion and voltage loss in the wiring.
The following fuses should be checked for your A/C clutch issue. Pass Compartment Fuse Panel: Fuse #14-5amp. Power Distribution Box: Fuse #47-15amp (Eng.#1) and Fuse #49-15amp (A/C Clutch). Also check Micro Relay #24 A/C Clutch as well as the A/C Clutch Diode in the same box.
You may want to remove or check the EVAP system under the car for dirt in filter areas, pinched hoses or lines and broken pieces if you've backed into anything. I remember reading of a fellow who cured his slow fill on an 05-06 by cleaning a vent filter on the evap unit.
Did you repair catalyst efficiency code? If not and your check engine light is On all the time how will you know if engine problems are arising?
Good Luck.
Good Luck.
Good Luck.
Good Luck.
I applaud you for trying a S/C install. It's not the kind most backyard mechanics would try. It's going to be a matter of rereading the install instructions and verifying your install. You're also going to have to locate that sensor and see if it's connected or damaged. Try using a mirror. It's a shame to have done all that work and then just convert back to stock. Good Luck.
http://www.bing.com/images/search?q=...ectedIndex=116
So, I've been having a lot of problems with my car recently, AC won't work, radio goes in and out, temp gauge doesn't work, and I can't fill the car up because it just spits the gas back at me. I took the car to a dealership to have them look at it and this is what I'm told:
They can't fix the radio because its aftermarket and they don't know what was done to it (the radio worked for 3 years prior to this), the AC has no leaks or anything like that but the compressor isn't being told to turn on, so the PCM is faulty, and that the EVAP device by the gas tank is broke so I have to replace it. That will cost $800. How does that just all of a sudden decide to not work?
Sigh, I think I'm going to end up selling this hunk of crap unless I can find some way to fix these issues. Any ideas?
Deysha
I wish I could help the OP but I cannot.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
