Sponsored by:
Sponsored by:
New Koni shocks just arrived. Are they damaged? (Pics)
Old 09-04-2014, 09:20 AM
Rocket254
Rocket254's Avatar
Default New Koni shocks just arrived. Are they damaged? (Pics)
Just had new Koni's arrive today. When I took them out of the box, I noticed that the top shock's bushing seems to be, I guess, warped? In no way can I bend that back to a normal shape. I send this back, right?
Rocket254 is offline
Old 09-04-2014, 10:41 AM
13'GT Black
13'GT Black's Avatar
It looks damage, top shock bushing is skewed and bottom shock has a gap.
13'GT Black is offline
Old 09-04-2014, 12:59 PM
Rocket254
Rocket254's Avatar
Just received this response straight from Koni
"The bushings are not bent, they are rubber and are designed to flex. Once they are installed they will flex even more. I see no issues with those dampers."
You'd think these would have never made it past inspection...
Old 09-04-2014, 03:13 PM
jRaskell
jRaskell's Avatar
Considering the response you got from Koni was basically there's no problem, why would you think they'd fail inspection?
I personally don't see anything clearly wrong with them. The bushings will flex when installed on the car. If you could flex them yourself, then I would consider THAT a problem.
If Koni says they're ok though, then they're probably ok.
jRaskell is offline
Old 09-04-2014, 03:49 PM
oldfella
oldfella's Avatar
I bought some Monroes for my truck this year. Cheaper I know, but they were shodily assembled as well. They didn't look like that when I installed shocks in high school at Sears 40 years ago.
oldfella is offline
Old 09-04-2014, 03:59 PM
Derf00
Gentleman's Relish
Derf00's Avatar
If it's the bushing who cares, it won't make a difference. By the time you put it on the car and crush it will all look and work the same.
Take a straight edge and see if the mount itself is bent. If the centerline of the metal mount is off from one end to the other, THAT is a problem.
Derf00 is offline
baddog671
07-26-2016 01:20 PM
b8checker
10-08-2015 12:55 PM
UrS4
10-03-2015 06:23 AM
KingRando
10-02-2015 08:06 AM
b8checker
09-30-2015 07:11 AM
Quick Reply: New Koni shocks just arrived. Are they damaged? (Pics)
