Sponsored by:
Sponsored by:
Steeda triple pass heat exchanger. WTF!
Old 09-19-2014, 08:06 AM
Andy13186
Andy13186's Avatar
Originally Posted by ghunt
I've put together all kinds of things that have had a flat washer with a lock washer on top. The flat washer helps keep the lock washer from damaging the surface you're tightening the bolt down on.
whats the purpose of the crush washer there then?
Andy13186 is offline
Old 09-19-2014, 11:57 AM
ghunt
ghunt's Avatar
That's a split lock washer, not a crush washer.
ghunt is offline
Old 09-19-2014, 12:29 PM
Andy13186
Andy13186's Avatar
Ahh thanks, I thought those were called crush washers and googled that, it said they were used to provide a tight seal to prevent leaks, i didnt see any reason for that but a split lock washer prevents loosening of the bolt in areas that have vibration, so that makes sense.
Old 09-19-2014, 12:34 PM
ticopowell
ticopowell's Avatar
I vote to get a new bolt, but make sure it is just barely bigger so you don't damage anything behind it.
If you want to try and flatten the split lock washer all I can think of would be vicegrips, but then you have the issue of where to squeeze, and how to turn the bolt while it is under pressure from the vicegrips.
Good luck!
ticopowell is offline
Old 09-19-2014, 03:40 PM
ghunt
ghunt's Avatar
Flattening the lock washer would defeat the purpose of the lock washer...
Split lock washers are supposed to work on a "spring" effect by putting upward pressure on the bolt head to keep it from turning. But, I don't really think split lock washers work very well because they aren't actually made of spring steel like wave lock washers are, and they always end up flattened out by the bolt anyway.
Really, you probably don't even need the lock washer there. What is it threading into? Is it a blind hole or open on the other side?
ghunt is offline
Old 09-19-2014, 04:00 PM
gmoran1469
gmoran1469's Avatar
yeah but there is still enough spring left in a lock washer for it to do it's job correctly.
Personally, I would just take the lock washer off and put some blue loc-tite on it. If you really wanna be safe, break out a tube of the red.
gmoran1469 is offline
Old 09-19-2014, 09:19 PM
tj@steeda's Avatar
Hello,
I am sorry you are having issues with the heat exchanger & parts supplied. We have installed this unit on several of our cars without issue.
Please send me your information to tim@steeda.com & I can put you in contact with one of our installers to help with your issues.
Best Regards,
TJ
tj@steeda is offline
Old 09-19-2014, 10:11 PM
2007CalSpec
2007CalSpec's Avatar
Update: I cut off the flat washer and it still won't give me enough reach to start threading the bolt into the U-nut. I'm now certain that I will also need to remove the lock washer for this to work.
Interestingly, I found this picture of an install that 5.0 Mustang & Super Fords did and it appears there's no washers at all. It's just a bolt. Could that be why the instructions say to use blue loctite? Because they had no washers when the instructions were written? Somehow I got bolts with two washers? Hmmm...
http://image.mustangandfords.com/f/5...inlet-hose.jpg
2007CalSpec is offline
Old 09-20-2014, 04:19 AM
rebus
rebus's Avatar
Here is your split washer failing.
http://www.boltscience.com/pages/jun...ringwasher.htm
A split washer against a hardened washer will spin against the washer. The split washer must be able to bite into both surfaces to be effective. Split washers are old tech, and not always that reliable. Steeda could be using button head bolts with thread sealant, like Afco, or an integral washer type bolt. I used pan head screws with Vibra-tite thread locker on my Afco HE with Spal fans. It was designed to be used with the LW so it won't hurt to use it, but you could also toss the LW's, keep the flat washers, and use locktite, as long as the bolts dont pierce the heat exchanger core tubing.
rebus is offline
Old 09-20-2014, 05:07 AM
jz78817
jz78817's Avatar
split lock washers just plain don't work. I agree, I'd just toss 'em and use Loctite.
jz78817 is offline
Quick Reply: Steeda triple pass heat exchanger. WTF!
