Security System Going Nuts - Videos Included
Hey All,
So recently I've noticed that i've had some troubles at start up with what I believe is the security system...knows as "PATs"?
I've attached a link to a video i just took of the issue. It's intermittent but managed to catch it and then took a video of how i normally start my car before the error happens.
It all seemed to start after I went to the dealership for an H02s issue a few months back and they said "we updated your computer because you had an older version, this should fix the problem" and I think that has something to do with this...
Since then i've seen it intermittently, but more so now than before. I've tried swapping keys as I've read there's a chip in the key that interfaces with the computer. The same error is produced. There are NO aftermarket security systems on the car, just the factory one.
The Error
https://www.youtube.com/watch?v=fK3k...ature=youtu.be
Normal Start
https://www.youtube.com/watch?v=XTmg...ature=youtu.be
I have always let my car go through it's initial setup before trying to turn over the engine like I do in the second video. In the case that I have detected the light going bezerk I haven't tried to start it. I just take the key out, open the door and then try again and so far its worked.
Thoughts????
The Error
Normal Start
Thoughts????
As of this morning I just went thru my start up procedure like video 2 and the wrench light illuminated. I could hear the fuel pump priming the engine then clicking and doing it again.
I did not start it but instead removed the key and tried again with no faults...fired right up.
What's going on???
What's going on???
09-10-2015 08:39 PM
