Sponsored by:
Sponsored by:
Check Engine Light --> Cam sensor
Old 10-22-2014, 05:12 PM
moosestang
moosestang's Avatar
Originally Posted by BeastMachine67
interesting...I should have it tested. It seems to still be charging though
It will keep charging, the problem is it leaks AC current into your DC system and causes sensors to go haywire. It could potentially damage electronics. I replaced mine with a PA alternator from americanmuscle.com as a preventative maintenance. I still have the stock one sitting on the shelf.
moosestang is offline
Old 10-22-2014, 07:42 PM
jz78817
jz78817's Avatar
yeah, this. the alternator is actually a three-phase AC generator, and it has banks of diodes to rectify the AC waveforms into DC. if the rectifiers start to fail, the alternator will still output power but it'll have a ton of "ripple" (residual AC noise riding on the DC current.) Normally the battery filters out minor ripple but a failing rectifier can overwhelm that. Excess ripple on power circuits can interfere with low-voltage signals like that from a cam sensor.
jz78817 is offline
Old 10-24-2014, 01:49 AM
808muscle
808muscle's Avatar
With 32k and 8 years old that would probably be a good idea for me too. I would hate to have it fail on race night.
808muscle is offline
Old 10-30-2014, 02:23 AM
BeastMachine67
BeastMachine67's Avatar
what can happen if it doesn't get replaced?
BeastMachine67 is offline
Old 10-30-2014, 04:06 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
Your car would be renamed as Flattery 'cause it would get you nowhere.
Dino Dino Bambino is offline
Old 10-30-2014, 09:20 AM
jz78817
jz78817's Avatar
you should be on SportsCenter.
jz78817 is offline
Old 10-30-2014, 04:07 PM
2005Redfire6
2005Redfire6's Avatar
Will have to keep this issue/solution in mind
2005Redfire6 is offline
Old 10-31-2014, 07:36 AM
Dino Dino Bambino
Ha ha. LOL.
Old 10-31-2014, 05:24 PM
Simon1
Simon1's Avatar
Most likely nothing but getting stranded on the side of the road, which is what happened to me.
But, damaged electronics is possible. The usual thing that would happen is your battery would get damaged, but, it doesn't always happen. Mine was fine.
Simon1 is offline
Old 11-02-2014, 01:45 PM
BeastMachine67
hmmm...the battery thing makes sense. I think the battery that was on there before I replaced it was only 1yr old
Quick Reply: Check Engine Light --> Cam sensor
