Sponsored by:
Sponsored by:
Throttle hangs at 4000RPM at WOT
Old 11-13-2014, 06:13 PM
04AZUREBLUEMACH1
04AZUREBLUEMACH1's Avatar
Default Throttle hangs at 4000RPM at WOT
2010 Shelby GT500 ~75,000mi
No matter what gear I am in, when I floor it, the tachometer almost always stops at 4000RPM OR comes back to ~4000 after being higher. The boost gauge seems to stay where it should (8psi). What could be causing this?
This happens with Autotrac On, Traction Off, and Sports Mode. I noticed there is no clutch TSB as there was for the 07-09...
Thank you as always!
04AZUREBLUEMACH1 is offline
Old 11-13-2014, 09:24 PM
cruisin5268d
cruisin5268d's Avatar
It could be a throttle body issue, but if it stops exactly at 4,000 everytime then I doubt it. I'm sure someone will be along soon that knows exactly what is wrong.
cruisin5268d is offline
Old 11-13-2014, 10:42 PM
04AZUREBLUEMACH1
Thanks. I JUST had the cats knocked out, but it was doing it before. Never had this problem with my catless 07.
Old 11-14-2014, 06:38 AM
PNYXPRESS
PNYXPRESS's Avatar
Does the engine stay revved up or is the tach just sticking at 4k? Does the tach suffer from stepper motor failures like the other gauges?
PNYXPRESS is offline
Old 11-14-2014, 09:59 AM
04AZUREBLUEMACH1
It's more prominent now and seems that the engine will rev high and not provide oower to the wheels. I smell clutch, so I'm assuming it's going out.
Please tell me there is a clutch TSB for 2010's?
Old 11-14-2014, 12:52 PM
04AZUREBLUEMACH1
One more observation... I can leave the car in gear, let off the clutch pedal, and the car doesn't die. Seems like the clutch is staying engaged. Anything I can do short of towing and getting a new one?
Thanks!
Old 11-14-2014, 01:06 PM
PNYXPRESS
PNYXPRESS's Avatar
Sounds like the clutch is gone or completely glazed over. Either way gonna need a new clutch
Old 11-14-2014, 01:35 PM
04AZUREBLUEMACH1
Safe to limp it 20mi without damaging anything else but the clutch which is already toast?
Old 11-14-2014, 07:02 PM
PNYXPRESS
PNYXPRESS's Avatar
You run the risk of destroying the flywheel if it isnt already scorched. There is also the chance the clutch will completely let go leaving you stranded in the middle of the road in traffic.
Old 11-14-2014, 07:08 PM
cruisin5268d
I agree with the others.
A short trip on a flat bed wrecker is much cheaper than damaging other components. Call around to several tow services and see who will offer you the best price.
UrS4
10-03-2015 06:23 AM
BeatnikFink
10-01-2015 08:00 PM
Florida Regional Chapter
09-30-2015 08:04 PM
guitarman376
09-30-2015 05:54 PM
GimpyHSHS
09-18-2015 12:27 PM
Quick Reply: Throttle hangs at 4000RPM at WOT
