Sponsored by:
Sponsored by:
whoever was responsible for the front control arms for the S197 needs a talkin' to
Old 12-16-2014, 02:17 AM
drewsky
drewsky's Avatar
Sway bar end links.. Even a 1/4 turn loose will make a ton of clunking noise. I didn't believe it till I tried it also. Added some lock tight and snugged them down. The control arms could be going or replaced with bad refurbished ones. But this is an easy check before anything else
drewsky is offline
Old 12-16-2014, 09:01 AM
loots06
loots06's Avatar
Originally Posted by loots06
Check the end links on the sway bar they might be loose. Best way is to remove the front wheels and check for play on the sway bar end links, a nice tug back and forth will do. When I had a problem similar to yours thats what it ended up being. GL
Yeap, very easy to be looked over, I know I did it.
loots06 is offline
Old 12-16-2014, 10:56 AM
808muscle
808muscle's Avatar
I had the same clunk. Hitting the road reflectors that divides the lanes would result in that horrible noise. Replaced strut mounts, no change. Replace front LCAs with the gt500 pieces and all is quiet. This was with 20k miles on the car. Quite sad when you think about it. Nothing should fail at such low mileage. I bought used so no warranty.
808muscle is offline
Gene K
10-21-2015 11:37 PM
guitarman376
10-11-2015 01:47 AM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
FivePointToTheOh
09-14-2015 03:35 PM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: whoever was responsible for the front control arms for the S197 needs a talkin' to
