Sponsored by:
Sponsored by:
Keeping cylinder head temp cooler
Old 02-21-2015, 08:09 PM
blmustang01
blmustang01's Avatar
Default Keeping cylinder head temp cooler
With AC off, cylinder head temps spikes to 210-219 F. With AC on the fan kicks in and keeps the cylinder head temps at 199-205 almost the entire time I'm driving. I've never seen above 219 F on my car. Does it matter to keep the temps down? What are your temps?
blmustang01 is offline
Old 02-21-2015, 08:31 PM
SpartaPerformance
SpartaPerformance's Avatar
Do you know what they are supposed to run at? Cooler doesn't mean its better if the non AC temps are in specified range.
SpartaPerformance is offline
Old 02-21-2015, 08:37 PM
blmustang01
Owner manual states nothing about what temps are acceptable but it stays at 2005-2007 mostly.
Old 02-22-2015, 03:54 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
It's not unusual (and my name isn't Tom Jones . If the AC is off, the electric fan is only going to switch on in low speed mode at a predetermined temp. If you're idling in slow traffic while the fan is still off, the coolant (and cylinder head) temp. could spike that high for a few seconds.
Dino Dino Bambino is offline
Old 02-22-2015, 09:17 AM
dj2014
dj2014's Avatar
^^^^^^What Dino said^^^^^^
dj2014 is offline
Old 02-22-2015, 10:42 AM
jz78817
jz78817's Avatar
the cylinder heads are the hottest part of the engine. 210 or so is fine.
jz78817 is offline
Old 02-22-2015, 05:27 PM
blmustang01
Cool thanks. I think it would take tremendous heat to warp the cylinder heads, maybe above 260 F is the breaking point. I just hate seeing it spike then try to get to 2007 where it mainly idles at.
Old 02-22-2015, 09:23 PM
leomccoy1313
leomccoy1313's Avatar
I usually my 2008 V6 mustang at 600 degrees. Unless I put coolant in it, I usually dont because I like it to heat up really quick because its cold in Northern California.
leomccoy1313 is offline
Old 02-23-2015, 01:03 AM
Dino Dino Bambino
The issue with cylinder head warpage or the head gasket blowing from an engine overheat is more likely when you have an aluminum head on an iron block (dissimilar metals expanding at different rates).
Aluminum dissipates heat faster than iron and thus aluminum engines run more efficiently at a slightly higher temp.
Looks like I have company with another comedian in the house .
Old 02-23-2015, 05:50 AM
blmustang01
Lol, for a second I thought you were serious.
Quick Reply: Keeping cylinder head temp cooler
