Sponsored by:
Sponsored by:
Clicking from behind Dash?
Old 03-26-2015, 08:07 PM
Joolander
Lord High Protector
Joolander's Avatar
Default Clicking from behind Dash?
So today headed home from work, I noticed an odd behavior in my car
Whenever I turn the ignition to the ON position (starting or not), there is a rapid clicking that comes from behind the instrument panel behind the speedometer, and it lasts about 2 seconds
It's not throwing any codes, and runs perfectly otherwise
So WTF is happening?
Joolander is offline
Old 03-26-2015, 08:26 PM
99GTvert
is my username.
99GTvert's Avatar
A/C on or off?
99GTvert is offline
Old 03-26-2015, 08:28 PM
Joolander
Lord High Protector
Joolander's Avatar
On. HMm hadn't considered that.
The A/C works great though
Old 03-26-2015, 09:54 PM
jwog666
jwog666's Avatar
turn off climate control completely anc see if it goes away. sometimes the elecric blend and mode door motors will make noise durring their test sweep on startup.
jwog666 is offline
Old 03-26-2015, 11:01 PM
Lethaldosage423
Lethaldosage423's Avatar
the blend door actuators (motors that control your HVAC blower doors for hot/cold or air direction) are little plastic stepper motors. the teeth break or strip on them causing them to just click and make an annoying noise. that would be my guess. not an uncommon issue.
turn the key on and air on. now play with the hot/cold **** and see if the noise changes or if your air temp changes.
now play with the air direction and see if the noise changes or if the air direction changes. this should help narrowing it down
Lethaldosage423 is offline
Old 03-28-2015, 02:51 PM
cruisin5268d
cruisin5268d's Avatar
I have the same issue on my 2010. It's time to sell her and I should probably fix it, but haven't seen any guide to replacing it/them.
cruisin5268d is offline
Old 03-28-2015, 07:00 PM
kenthicken
kenthicken's Avatar
Blend door actuator. 100%.
kenthicken is offline
Old 03-28-2015, 09:50 PM
Joolander
Lord High Protector
Joolander's Avatar
Yeah the issue doesn't happen when the heater is on, only when I turn on A/C. So blend door actuator makes sense
Can I just go into a shop and say "blend door actuator"? I have a feeling they'll think I'm speaking mandarin
Old 03-28-2015, 11:56 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Que?
They will understand...if they don't...freeze, turn around, slowly, and quietly walk back out....
Derf00 is offline
Old 03-29-2015, 07:18 AM
jpplaw
jpplaw's Avatar
If the noise is from the center area of the dash behind the center stack up high, you have to isolate whether it is the drivers side or passenger side actuator. To figure out which one has gone bad, you may have to reach up under the dash and feel the motors while someone operates the controls to replicate the noise. There are actually 4 actuators - A, B, C, and D. Actuators B, C, and D are accessible from the passenger side, A is on the driver's side. A & B are the ones that make noise behind the center stack up high. Rock Auto carries them.
jpplaw is offline
Quick Reply: Clicking from behind Dash?
