My gauges in the center, temp, oil, battery, whatever the four small ones are, appear foggy. Does anyone have a fix for this? Or know the cause? I'm new to the mustangs.
is it foggy from condensation or just hard to see through? you may need to remove the cluster and use a good plastic polish to clean it (unless the discoloration is on the outside of the lens, then you don't have to remove cluster).
It looks like a slight discoloration probably on the inside. Kinda like a headlight lens getting foggy. I was just curious if this was a common issue or just something weird I got.
