Sponsored by:
Sponsored by:
Transmission
Old 06-17-2015, 09:52 AM
Vesper07
Vesper07's Avatar
Default Transmission
So about a year ago I bought my 07 4.0 with an automatic transmission. Just recently I've been noticing that when I put it in reverse it takes around 4 seconds to actually engage and when it does engage it's more of jump than a regular transition. Any help would be great.
Vesper07 is offline
Old 06-17-2015, 05:44 PM
Derf00
Gentleman's Relish
Derf00's Avatar
That's the reverse solenoid getting gummed up or worn out. Very common on the 5r55s tranny.
When was the last time the fluid was changed in the tranny? It should be done every 30k. If changing the fluid doesn't fix it you will need to service the solenoid directly.
Drop the pan and remove the four bolts that hold the solenoid in, take it apart, and replace its piston and spring.
Derf00 is offline
Old 06-18-2015, 07:26 PM
Vesper07
Vesper07's Avatar
Not sure when it was changed. I know I when I bought it, it already had 160k on it. As far as the tranny service I'm not sure. Thanks for the tip
Vesper07 is offline
4cylinderplus2
10-09-2020 07:45 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Transmission
