Sponsored by:
Sponsored by:
Engine Control Module Ecm (limp Mode) Mystery Help
Old 12-03-2015, 02:10 PM
closstang
closstang's Avatar
Default Engine Control Module Ecm (limp Mode) Mystery Help
Ok guys, my back is up against the wall and I’m hoping this has happened to someone else that was able to itdentify the problem and get it fixed. I was driving home two months ago going about 70 mph on a relatively flat road when all of a sudden my 2007 Mustang GT seemed to shut down, but the engine was still running. I lost control of RPMs and wasn’t able to go more than 10 mph with the Check Engine light lite up along with a Wrench light which upon further research turned out to be the Electric Throttle Control (Limp Mode) light as identified in my owner’s manual. Got it towed straight to the dealership, where they informed me that I had a bad Engine Control Module (ECM) or as the dealership labeled it a Powertrain Control Module (PCM). So after the hefty price-tag to fix it, I figured go online and find it cheaper because the dealership stated this was not a part that was available new and I would have to purchase a remanufactured part anyways. I ordered it online and took the Cardone remanufactured ECM to them to install. They then informed me that the car was running again, but the ECM wasn’t allowing the Intake Control Motors to function properly stating that the ECM was no good. So, my next step was to send this one back and just send my in directly to Cardone through Autozone, to get rebuilt. I then contacted Autozone to follow up on status and they contacted Cardone, which in turn told Autozone that the ECM was good and not coming up with any errors. (Note that this is now the original ECM that came with the car that they are stating is OK) I’m pretty much out of options here and don’t know what else I can do at this point. Any suggestions would be greatly appreciated. ***Also, my Mustang is all stock, no upgrades or tunes.
closstang is offline
Old 12-03-2015, 03:54 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Hmm, u don't want to hear this but...I'd take it to another dealer. Sounds like your dealer doesn't know what they are doing. Especially if an aftermarket re-manufacturer is telling you/them that your Original one is fine.
What made the dealer determine the original ECM was bad? There are a few non-related ECM issues that can make the car go into limp mode (Severe misfires, bad crank/cam sensors, bad TPS, bad MAF, bad Throttle Body...)
Derf00 is offline
Old 12-05-2015, 09:10 AM
bl817
bl817's Avatar
what other codes were pulled? there should have been several more at least. we need more info. could be a lot of things as stated above. your alt could be going bad as well.
bl817 is offline
piotrek53
10-13-2015 06:54 PM
b8checker
10-08-2015 12:55 PM
Seanam
10-04-2015 10:15 AM
69Volunteer
09-30-2015 10:39 AM
b8checker
09-30-2015 07:11 AM
Quick Reply: Engine Control Module Ecm (limp Mode) Mystery Help
