2010+ aftermarket projectors
I did a quick search couldn't find anything so sorry if this has been posted. But has anyone taken a look at theses. The appear to be replacements for those of us without the stock HID option. They don't look bad but I would like to see them on a car. I could definitely live without the halos. Here's the link to the ebay listing.
--Edit
Ok so I did some more searching and found some more listings
listing1
listing2
listing3
--Edit
listing1
listing2
listing3
Yeah I was looking at the separate hi/low. It looks like there is two styles one of the listings says it takes a h11 and a h1, the other is said to use have hi/low projectors and use a h9 bulb which I believe is a single filament bulb so I'm guessing it would have to use a solenoid type projector. Then again I would put anything past an ebay listing.
I had similar lights on my 05 and didn't hook the halos and leds to power because i didn't ;like them. the install isn't that hard on these types of lights, that said they were no where near as bright as the stock lights on my 05. it was very similar light output to my 10 with the tints on, the projectors were a bit less bright even. The bulbs were single on the ones i had with dual filaments.
Well I emailed the seller to see about the projectors.
I think I might give these a try. I had planned on retrofitting the stock housings which is what I did on my last car which was a royal pain. Next spare $400 I get is going toward these or a tuner.
Dear *,
Thank you for your inquiry, there's a flip inside the housing, will flips when high beam is on.
Thanks
revotec
----- Original Message -----
To: saisai@revotec-usa.com
Sent: Saturday, August 07, 2010 11:49 AM
Subject: * has sent a question about item #140436896681, ending on Aug-12-10 15:55:19 PDT - 2010 FORD MUSTANG CCFL LED PROJECTOR HEADLIGHTS BLACK
Dear revotec,
I see these headlights use a single projector for hi
and low beam. Since the H9 is a single filament bulb
do these projectors use a solenoid activated cut off
shield to switch between hi and low beam?
Thanks
revotec
Dear revotec,
Dan04COBRA
09-30-2015 11:46 AM
09-24-2015 09:18 PM
09-17-2015 07:32 PM
