3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Gears and driveshaft?
Old 10-05-2011, 12:25 PM
solidhadriel
solidhadriel's Avatar
Originally Posted by hogasswild
I think either 3.55 or 3.73 would be the sweet spot for gears. As for the DS, not only do you shed like 8-10lbs of rotational mass. The independent dyno results also show about 8hp/tq increase as well. A little pricey for the power output, but combined with the added strength, reliability and less rotational mass I think it's worth it.
I would have to agree with Hogasswild here.
solidhadriel is offline
Old 10-05-2011, 06:39 PM
pro134
pro134's Avatar
i dont mean to contradict myself i just realized i worded my initial question poorly. And yes ive only seen the drive shafts for 500-700 and thats seems like an aweful lot but in the long run i guess it would be worth it if i continue to mod the car. the poeple i have heard of using 4:10s on their autos do almost no highway driving so i would assume thats why they prefer them since their RPM's are never high. But thank you both, i think im going to stick with 3.73 when i finally upgrade
pro134 is offline
Old 10-06-2011, 08:13 AM
Sterling_Beauty
Sterling_Beauty's Avatar
Yes, I have the 3.73 in my Stang and I love it.......4.10 are more for the strip and not for a daily driver. If you went with the 4.10 your MPG will take a huge hit not to mention high RPM's when on the highway! But it would be fast on the strip.
Sterling_Beauty is offline
Old 10-06-2011, 09:11 AM
solidhadriel
No problem man. The reason I'm being harsh on you is because I don't want to see you mod your car without knowing what those mods do. Mods can void your warranty, destroy your differential, throw error codes, and cause engine problems if you don't know what your doing.
Old 10-06-2011, 09:12 AM
pro134
pro134's Avatar
Yea that's was my main concern is MPG because I don't go to the strip very often. I need to find a shop in my area to install them first
pro134 is offline
Old 10-06-2011, 09:20 AM
pro134
pro134's Avatar
Sorry can't find the edit but I understand completely solidhadriel its not problem thanks for looking out for your fellow member
pro134 is offline
Old 10-06-2011, 05:42 PM
hogasswild
hogasswild's Avatar
What kind of mpgs are you seeing in the city and highway? What size are your tires?
hogasswild is offline
Old 10-06-2011, 08:22 PM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
The drive shaft subject is one that is often debated.
Some love it and say it helps, some hate it and say it causes problems.
I'd say it can do both. I've seen and heard it enough in different situations.
I'm always on the YES side of upgrading the gear ratio from stock as long as you
don't have a really aggressive ratio from the start.
Blacksmoke is offline
Old 10-07-2011, 08:22 AM
Sterling_Beauty
Combined Avg. of 24/25mpg
Old 10-08-2011, 06:08 AM
hogasswild
hogasswild's Avatar
That's not bad. As long as I can get 27 mpg on the highway I'll make the switch.
Quick Reply: Gears and driveshaft?
